Hysteresis needed in 741 Op-Amp circuit
Discussion in 'Electronic Design' started by John Fields, Jun 14, 2004.
  1. John Fields
    John Fields Guest
    1. THE THERMISTOR
    For a good discussion of how thermistors work, refer to:
    http://www.epcos.com/inf/50/db/ntc_02/00170027.pdf
    For the purpose at hand, (determining how the change in resistance
    affects the voltage into the comparator) refer to the "1006" column
    in:
    http://www.epcos.com/inf/50/db/ntc_02/01470178.pdf
    and you'll notice that at 15°C the value of Rt/R25 for 15°C is 1.4883,
    and at 35°C it's 0.686.
    What that means is that if the thermistor has a resistance of 10000
    ohms at 25°C, then at 15°C it'll have a resistance of 14,883 ohms, and
    at 35°C it'll have a resistance of 6860 ohms.
    2. THE VOLTAGE DIVIDER
    Now, if we connect the thermistor in series with a resistor and apply
    a fixed voltage across them, like this:
    E1
    [R1]
    +---->E2
    [RT1]
    GND
    Then when temperature increases and the resistance of the thermistor
    (RT1) decreases, E2 will also decrease. Conversely, when the
    temperature to which RT1 is exposed decreases, E2 will increase.
    The exact relationship is:
    E1 RT1
    E2 = ------
    R1+RT1
    so, if we make E1 = 12V and R1 = 100kohms, then at 15°C,
    12*14883
    E2 = ------------- ~ 1.555V
    100000+14883
    and the power being dissipated in the thermistor will be:
    E² 1.555²
    P = --- = ----- = 162µW
    R 10000
    At 35°C, the potput voltage will be:
    12*6860
    E2 = ------------- ~ 0.7703V
    100000+6860
    and the power dissipated by the thermistor:
    E² 0.7703²
    P = --- = ------- = 86µW
    R 6860
    The power dissipated in the thermistor may be enough to cause a
    self-heating error to occur, but you'd need to look at the data sheet
    for the particular thermistor you're using to make sure.
    In any case, if the self-heating error is negligible with respect to
    the accuracy you're looking for, with 1.555V out at 15°C and 0.770V
    out at 35°C, that's a spread of 780mV from one end of the temp range
    to the other, which is pretty good.
    3. THE REFERENCE DIVIDER.
    If we now connect our thermistor circuitry to the + input of a voltage
    comparator, like this,
    +12V>---------+---------+----+
    [100K] | [RL]
    | | >--+----->OUT
    [RT1] |
    GND>----------+---------+---------->GND
    and we arrange things so that the voltage on the - input is 0.770V,
    then when the voltage on the + input rises to 0.770V or higher, the
    comparator's output transistor will switch off and the voltage on OUT
    will be pulled up to +V through RL.
    We can do that by using another voltage divider, like this:
    +V>---+-------+-----+----+
    E1--+ [100K] | [RL]
    [R1] +----|+\ |
    | | | >--+----->OUT
    E2--+-------|----|-/
    [R2] [RT1] |
    GND>--+-------+-----+---------->GND
    and selecting R1 and R2 so that the voltage at their junction will be
    0.770V. An easy way to do this is to look at the comparator data
    sheet to find out what the required input current is and making the
    resistances small enough to swamp out that current. For the LM311,
    that comes out to about 350nA, so if we make the divider current 350µA
    the LM311's input currents will contribute about a 1% error to the
    divider's output voltage. Better yet, let's make the divider current
    about 1mA and use 1% resistors for the divider. That way, most of the
    error will be in the resistors, where we can easily account for it.
    Since we've got a 12V supply, and 10kohms is a standard 1% value, and
    12V into 10k is about 1.2mA, let's make R1 = to 10k and figure out
    what R2 needs to be to get us to 0.770V.
    Since our new divider is the same as the old one, we can write:
    E1 R2
    E2 = ------
    R1+R2
    and rearrange to solve for R2:
    E2 R1
    R2 = -------
    E1-E2
    which gives us:
    0.770*10000
    R2 = ------------- = 685.66 ohms
    12-0.770
    681 ohms is a standard 1% value, so plugging that into
    E1 R2
    E2 = ------
    R1+R2
    to get the voltage into the comparator's - input gives us:
    E1 R2 12*681
    E2 = ------- = ----------- = 0.765V
    R1+R2 10000+681
    That's a voltage error of 5 parts out of 770, which is just a little
    over 1/2 a percent, so since the resistor tolerance error will
    dominate at this point we have a tentative solution, and our circuit
    now looks like this:
    | [100.0K] | [RL]
    [10.0K] +----|+\ |
    | | | >--+----->OUT
    [681] [RT1] |
    4. THE VARIABLE REFERENCE.
    Now, we could use the same procedure to figure out a new R2 for a temp
    of 15°C, and switch between the two, or figure out a whole bunch of
    different R2's and switch them in and out for the different temps we
    wanted to set to between 15 and 35°, but a much nicer way to do it
    would be to use a pot.
    In order to be able to do that, our circuit changes to:
    [R1] [100.0K] | [RL]
    | | | >--+----->OUT
    [R2]<-----|----|-/
    [R3] [RT1] |
    Where R1 is a pot and R1 and R3 are 1% resistors used to set the ends
    of the pot's resistive element to the voltages corresponding to 15°
    and 35°C.
    Just to get a feel for things, if we want the end of the pot connected
    to R1 to be at the higher endpoint voltage (1.555V) and we keep R1 at
    10k,then the series combination of R2 and R3 has to be:
    E2 R1 1.555*10000
    R2+R3 = ------- = ------------ ~ 1489 ohms
    E1-E2 12-1.555
    and if we want the lower end of the pot to be at 0.77V, then since
    there's
    E1 12
    I = ----------- = ------------ = 1.04mA
    R1+(R2+R3) 10000+1489
    flowing in the circuit, and
    E
    R = ---
    I
    0.77V
    then R3 = ------- = 740 ohms.
    1.04mA
    Since 750 ohms is a standard 1% value, that leaves
    1489ohms - 750ohms = 739 ohms for the pot.
    739 ohms is _not_ a standard end-to-end resistance for a pot, so we'll
    have to do something to fix that. Since R1R2R3 is a voltage divider,
    all we're really concerned with is the ratios of resistances, so let's
    scale up the 739 ohms to 1000 ohms, which is a standard end-to-end
    resistance for pots, and then scale up everything else and see what
    happens.
    1000/739 = 1.353, so R1 needs to go to 13530 ohms, R2 will go to 1000
    ohms and R3 will need to go to 1000 ohms as well. So now, since the
    closest we can get to 13530 ohms with 1% resistors is 13700 ohms, our
    string now looks like this:
    +12V
    [13.7K]
    [1000]<----Vout
    [1000]
    GND
    With the wiper at the top of the pot, Vout will be:
    12*2000
    Vout = --------- = 1.528V
    15700
    and at the bottom of the pot it will be:
    12*1000
    Vout = --------- = 0.764V
    15700
    (1.555-1.528)*100
    So, we'll have an error of ----------------- ~ -1.7%
    1.555
    (0.770-0.764)*100
    on the high end, and ------------------- = + 0.78% on the high end.
    0.764
    Not too shabby, and now, after adding all the resistor values and
    introducing the hysteresis resistor, our circuit looks like this:
    +12>---+--------+-----+-------+
    [13.7K] [100.0K] | [RL]
    | +-------[Rh]--+
    | | | >-----+----->OUT
    [1000]<-----|----|-/
    [1000] [RT1] |
    GND>---+--------+-----+---------->GND
    5. HYSTERESIS
    Since a comparator has what amounts to essentially infinite gain, if
    its input signals are allowed to move through the switching region
    slowly, any noise present on the inputs during that time _will_ cause
    the output to swing wildly between its limits. If slowly moving
    signals _must_ be accommodated, the cure for the problem is to cause
    the input(s) to quickly move out of the sensitive region when the
    output changes state. This is done by connecting the output to the
    non-inverting input so that when the non-inverting input goes more
    positive than the inverting input, causing the output to go high, a
    little of that high-going output signal is coupled back to the
    non-inverting input, causing it to quickly go even higher, moving it
    quickly out of the noisy region, thus preventing the "chatter" which
    would otherwise surely occur. In this instance, that positive feedback
    is called "hysteresis".
    The amount of hysteresis intoduced into the circuit can be controlled
    by selecting the resistance of the feedback resistor, which is part of
    yet another voltage divider.
    Looking at the output of the circuit above in a little more detail
    shows us that the output stage is a transistor with an open collector
    which pulls the putput down to ground when it is turned on and allows
    the output to float when it's turned off, and what's important to
    remember is that when the non-inverting (+) input is more positive
    than the inverting (-) input the output will be turned off, allowing
    current to flow from the supply and through RL into whatever is
    connected to the comparator's output.
    +12>---+--------+-------+-----+
    | +--[Rh]-------+
    | +----|+ C|-+----->OUT
    | | |LM311 |
    [1000]<-----|----|- E|-+
    [1000] [RT1] | |
    GND>---+--------+-------+-----+----->GND
    Since the LM311 can sink 50mA, there's no reason why it can't be used
    to dirctly drive a 12V relay with a coil resistance of
    12V
    R = ----- = 240 ohms
    50mA
    or greater, so adding that circuitry yields:
    +12>---+--------+-------+-----+-------+
    | | | |K | O--> |
    [13.7K] [100.0K] | [1N4001] [COIL]- | - -|
    | | | | | | O------>COM
    | +--[Rh]-------+-------+ |
    | | | | +----------->NO
    | +----|+ C|-+
    | | |LM311 |
    [1000] [RT1] | |
    Checking the sense of the output, we find that as the thermistor heats
    up its resistance will decrease until it causes the comparator's +
    input to go more negative than its - input, which will cause the
    output transistor to turn on, energizing the relay, so this a cooling
    thermostat. That is, if it gets hot enough to turn on the relay, the
    relay will turn on the A/C, cooling the thermistor until the voltage
    on the + input goes more positive than the voltage on the - input,
    turning off the output transistor, turning off the relay, then
    turning off the AC until it gets hot enough to turn it back on...
    Now that we have that all figured out, if we simplify the circuit by
    replacing the comparator's input with a resistor and its output with a
    switch we'll have what amounts to:
    +12>---+---------+
    [100.0K] [240]
    +--[Rh]---+-+-------->Eout
    Ein---+----+ |
    | | O
    [RT1] [Rin] |
    GND>---+----+----------+---->GND
    If 240 ohms (the relay coil resistance) << than Rh and Rin is >> RT1,
    (which they will be) then the circuit further simplifies to:
    +12>---+-------------+
    [100.0K] |
    +--[Rh]---O |
    | O--> |<--O
    Ein---+ |
    [RT1 |
    GND>---+----+
    So that with the switch in the rightmost position we have:
    +12>---+------+
    [100.0K] [Rh]
    +------+--->Ein
    [RT1]
    GND>---+
    And with the switch in the leftmost position we have:
    +12>---+
    [100.0K]
    +------+--->Ein
    [RT1] [Rh]
    GND>---+------+
    Since, at 15°C, (without Rh in the circuit) we'll have an output
    voltage of 1.55V from the thermistor and, at 35°C, an output voltage
    of 0.77V, we'll have a 780mV change for a 20° change in temperature,
    which is a sensitivity of 39mV/°C. That won't be quite true over
    every increment of that range, since the thermistor is a non-linear
    device but, for now, it's close enough.
    Next, let's say that the accuracy spec's for the thermostat will
    allow, after everything else has been accounted for, an extra degree C
    to be used up to get the hysteresis we need. That means, since we've
    got a sensitivity of 39mV/°C, that we've got 39mV to play around with
    to get some hysteresis.
    Now, below 15°C our thermistor will exhibit a resistance > 14883 ohms,
    and if it warms up to 15°C, our circuit will look like this:
    +12>---+
    [100.0K]
    +---->1.55V
    [14883]
    GND>---+
    When this happens and the comparator's - input is set to 1.55V, the
    output will go low and turn on the relay, and what we'd like to do is
    to fool the thermostat into thinking that when that happens it's
    actually 16° outside so that it'll move the input switching point a
    little closer to ground to get away from the noise-susceptible input
    transition region.
    Since the thermistor resistance decreases when it gets hotter, what we
    can do when the output goes low is to parallel the thermistor with
    enough resistance to lower the 1.55 volts by one degree, to 1.51V
    (rounding the 39mV/°C sensitivity to 40mV/°C).
    Looking at the thermistor circuitry like this:
    E1
    [R1]
    +---->E2
    [R2]
    GND
    And setting E1 = 12V, E2 = 1.51V, and R1 = 100kohms,
    we can solve for R2, the total resistance we need to get 1.51V out by
    writing:
    E2 R1 1.51*100000
    R2 = ------- = ------------- ~ 14395 ohms
    E1-E2 12.0-1.51
    Since, at 15°, the thermistor will be at 14883 ohms, we'll need to
    parallel it with a resistor to make the combination look like 14395
    ohms, like this:
    E1
    [R1]
    +-----+--->E2
    [R2] [R3]
    GND
    Knowing that the equation for the total resistance of two parallel
    resistors is:
    R2 R3
    Rt = -------
    R2+R3
    and that R2 = 14883 ohms and Rt = 14395 ohms,
    we can rewrite it to solve for R3 like this:
    Rt R2 14395*14883
    R3 = -------- = ------------- ~ 439kohms
    R2-Rt 14883-14395
    The closest 1% resistor we can get which won't exceed our 1°C error
    budget is 432k, but that'll still give us nearly the 40mV of
    hysteresis we're looking for, so let's choose that value tentatively.
    Now, let's say the temp starts falling from that point. Since it's
    really 15° outside and we've fooled the comparator into thinking that
    it's 16°, it's going to have to fall to 14° for the comparator to
    think that it's 15° outside, but when it gets there the comparator's
    output will go open-collector and the feedback resistor will now be
    connected to +12V through the relay coil. If the coil looks like 240
    ohms its resistance will be negligible compared to the feedback
    resistor's 439kohm resistance, so since the thermistor's sensitivity
    is -401 ohms/°C, (assuming it's linear for the sake of this
    discusion...) its resistance will rise to 14482 ohms and the circuit
    will now look like this:
    12V 12V
    [100K] [439K]
    +-------+--->E2
    [14482]
    GND
    100k in parallel reduces to a total resistance of
    100000*439000
    Rt = --------------- = 81447 ohms.
    100000+439000
    So, the circuit further reduces to
    12V
    [81447]
    +---->E2
    [14482]
    GND
    And the voltage into the comparator's + input, E2, will now be
    12.0*14482
    E2 = ------------- ~ 1.812V
    81447+14482
    Since the [15°C] reference voltage on the comparator's -input will be
    sitting at 1.555V, that 1.812V represents a hysteresis of about 257mV,
    which represents the introduction of about a 6.6°C error. If the
    error spec is +/- 1°, that's very, very, bad.
    Fortunately, since the reason for the error is the asymmetry of the
    thermistor string, we can fix it by making the string symmetrical.
    That is, by making the series resistor and the thermistor the same
    value at the center of the thermistor's resistance range for the
    temperature range it will be sensing.
    For our thermistor, with an R of 14883 ohms at 15°C and an R of 6860
    ohms at 35°C, that comes out to 10,872 ohms for the series resistor,
    so with the nearest 1% resistor installed, our new circuit will look
    like:
    12V
    [10700]
    +---->E2
    [Rth]
    GND
    Now E2 will be 6.98V at 15°C (Rth = 14883 ohms) and 4.688V at 35°C
    (Rth = 6860 ohms), so the new voltage sensitivity will will be about
    115mV/°C.
    115mV is a lot, so if we limit our hysteresis to, say, 50mV that'll
    cause less than a 0.5° error, but let's see how it works out.
    Just like last time, if we want 50 mV of hysteresis we'll have to make
    the parallel combination of the 10.7k resistor and and the feeback
    resistor change the + input voltage to the comparator by the amount we
    want, which will be 50mV in this case.
    We really only have four cases to consider:
    The hysteresis when the temp is rising and falling through 15°C, and
    the hysteresis when the temp is rising and falling through 35°C.
    Looking at falling through 15°C first, we'll have:
    12V 12V
    [10.7K] [Rf]
    +-------+--->E2
    [14883]
    GND
    Since the resistance of the thermistor is increasing as it gets
    colder, the voltage at E2 will be increasing also. Without feedback
    E2 would be 6.98V when the thermistor got to 15°C (14482 ohms), and
    what we want to do with the feedback is to make it seem like it's a
    little bit colder than it really is when E2 gets to 6.98V, so that
    would mean making E2 jump a little more positive when the comparator
    output goes open collector.
    We can do that by paralleling the 10.7kohm resistor with a resistor of
    a suitable value and, using the procedure outlined earlier, we find
    that for a 50mV jump (from 6.98V to 7.03V) the parallel combination of
    the 10.7kohm resistor and the feedback resistor (Rf) needs to be 10522
    ohms, with Rf being equal to 632502 ohms. The closest 1% resistor is
    634kohms, which will give us an E2 of 7.02V as the temp falls through
    15°C, about 40mV of hysteresis over the non-feedback case.
    With the temp rises through 15°C and the comparator's output
    transistor turns on, our circuit becomes:
    12V
    [10.7K]
    +-------+--->E2
    [14883] [634K]
    GND GND
    and E2 will now become 6.91V, giving us 70mV of hysteresis.
    When the temp falls through 35°C, the circuit will become:
    12V 12V
    [10.7K] [634k]
    +-------+--->E2
    [6808]
    GND
    Without feedback, E2 would be 4.666V, but with feedback it'll be
    4.714V, giving us about 48mV of hysteresis.
    Finally, When the temp rises through 35°C, the circuit will become:
    12V
    [10.7K]
    +-------+--->E2
    [6808] [634K]
    GND GND
    and E2 will go to 4.636V, giving us about 30mV of hysteresis.
    So, here's the final schematic, and barring any fuzzy thinking, math
    errors, trypos, etc., all that's left to do now is to recalculate the
    padding resistors around the pot for the new voltage range and trim
    things up if you want/need more or less hysteresis, and it should be
    pretty much done.
    +--- >= 240 ohms
    +12>---+--------+--------+-----+-------+ /
    | | | |K | / O--> |
    [R1] [10.7K] | [1N4001] [COIL]- | - -|
    | | | | | | O------>COM
    | +-[634K]-------+-------+ |
    | | | | +----------->NO
    | +----|+ C|--+
    | | |LM311 |
    [1000]<-----|----|- E|--+
    [R2] [RT1] | |
    GND>---+--------+--------+-----+----->GND
    Simple, huh?^)
    PS...
    I've got some schematics for heating-cooling thermostats using
    LM393's, and if you'd like I can post them to
    alt.binaries.schematics.electronic.
  2. Robert Baer
    Robert Baer Guest
    ------------- SNIPped ------------
    .... a *VERY* long-winded paper that might be called a thesis (or
    mini-novel?).
    If you had a ?questiion? concerning hysteresis, it would have been
    nice to make a *BRIEF* synopsis of the problem.
    Else, do not waste bandwidth!
  3. Robert Baer wrote...
    Hah! That's some of the best bandwidth wasting we've seen here
    in some time.
    - Win
    (email: use hill_at_rowland-dot-org for now)
  4. Tim Auton
    Tim Auton Guest
    I concur. I found it a most interesting insight into how I would like
    to be able to design circuits. I'd probably have chucked a uC input at
    it long ago ;)
    Perhaps Robert Baer missed the thread in s.e.basics that prompted John
    Fields' post. I think it's on-topic here too.
    Tim
  5. Jim Thompson
    Jim Thompson Guest
    Go tell your mommy that you've been a bad boy and need your mouth
    washed out with soap.
    ...Jim Thompson
  6. John Fields
    John Fields Guest
    It wasn't a question. As Tim Auton noted, this was a reply, which I
    inadvertently posted here first, to several posts in a thread which
    originated on seb.
    Sorry you didn't find it at least interesting...
  7. Yup. A lot of effort went into that.
    Best regards,
    Spehro Pefhany
  8. I sure did as with all your posts. Absolutely brilliant. I love these
    exercises and I benefit from nearly all them. This NG is one of the
    most valuable sources I have ever found. Many thanks to you and the
    few other Titans in here that take the time to educate and advance the
    art through your unselfish sharing of your knowledge.
    Thanks again!
  9. John Fields
    John Fields Guest
  10. Terry Given
    Terry Given Guest
    Dont thank us John, just keep posting such excellent work :)
    Cheers
    Terry
  11. John Fields
    John Fields Guest
  12. John Fields wrote...
    We don't want you to get a big head. :>)
    - Win
  13. Terry Given
    Terry Given Guest
    I printed it to a PDF - it will be useful in the future, as I often find
    myself working with people who dont understand this sort of thing, and John
    kindly saved me from writing it myself :)
    - besides, it will frighten the hell out of my year 12 electronics students
    cheers
    Terry
  14. Fred Bloggs
    Fred Bloggs Guest
    What was the question this "paper" answers?
  15. John Fields
    John Fields Guest
    Check the same subject on seb.
    What the **** is it with some of you clowns, anyway?
    I do a guy a favor with a little tutorial to which he refuses to
    respond and then I get flak from some fucking idiot about wasting
    bandwidth, from you with your snide goddam "paper" bullshit, and from
    Givens with his "I was gonna write the same thing myself, but"...
    To hell with all of you niggardly sons of bitches.
  16. Jim Thompson
    Jim Thompson Guest
    Careful there, John, some ignorant Democrat will call you a racist ;-)
    ...Jim Thompson
  17. Rich Grise
    Rich Grise Guest
    My only criticism is that it might have been more appropriate to
    ..basics, or even both, since it's ASCII after all. :)
    Cheers!
    Rich
  18. Well John, there's a bright side, Fred didn't find any errors, he
    would have spotted them if there were any ;) I admire your energy
    and yes, many can go to hell. But you have to be patient, alas.
  19. Rich Grise
    Rich Grise Guest
    I found myself trying to figure out what kind of transfer function
    would be appropriate to map onto those 3 points ... since it's
    essentially impossible to guess, I looked it up from your reference,
    and decided, yup, I never would have got that one, nosireebob!
    Cheers!
    Rich
  20. Rich Grise
    Rich Grise Guest
    Yikes! Don't fawn, fer crissakes! None of these weenies deserves it -
    they all take their pants off one leg at a time! =:-O
    Cheers!
    Rich
