Hysteresis for the SW in LTspice question
Discussion in 'Electronic Design' started by Maynard A. Philbrook Jr., Dec 25, 2013.
  1. I am trying to emulate a spark gap effect using the SW component in
    LTspice and the parameter Vh = xxx seems to allude me !
    The help file leaves a lot to be desired and network searches
    simply point me to the same help file or youtube videos with no sound
    and very blurry images.
    Is the value for the hysteresis absolute below the trigger or is an
    offset from the trigger?
    I will say this, after experimenting with the values, I find that in
    this circuit I am playing with, if I don't get the Vh very close to the
    Vt value, Ltspice will never complete the simulation run, it just sits
    there and loops on some calculation that it never comes out of.. I
    Suppose I can change the step point, I using the default for now.
    P.S.
    The load this is shorting is from a secondary side of a HV
    transformer, much like a car coil would be.
    Jamie
  2. Den onsdag den 25. december 2013 20.31.42 UTC+1 skrev Maynard A. Philbrook Jr.:
    http://ltwiki.org/index.php?title=S_Voltage_Controlled_Switch
    would the neonbulb with changed voltages work ?
    -Lasse
  3. Fred Abse
    Fred Abse Guest
    Level 1 Vh positive:
    Switches abruptly at Vt-Vh and Vt+Vh
    Hence Vt=1 and Vh=0.5 will switch at 0.5 and 1.5
    Vt midway between switching points.
    Level 1 Vh negative:
    Switches smoothly (polynomial fit) at Vt-Vh and Vt+Vh
    /Examples/Educational/Vswitch.asc demonstrates this. You need to play with
    the .model directive to see the two modes As it comes, it uses Vh negative.
    Play with it to see how it works. This is what most people ever need.
    Putting "level=2" in the .model line, with Vh negative gives a function
    dependent on log(Roff/Ron)/pi, and log(1/(Roff*Ron))/2, with a tanh limit
    function. Jim would like that ;-)
    You probably never need worry about level 2.
    It's all in the help file, just not either intuitive, or well explained.
    LTspice also appears to honor Pspice switch syntax, which is different,
    too.
    Par for the course.
    See above
    Post the relevant .asc, and let's see what can be done.
    Like a spark plug?
  4. Fred Abse
    Fred Abse Guest
    Sorry, that's misleading/ambiguous.
    Hence Vt=1 and Vh=0.5 will switch at 0.5 and 1.5V. Vt is midway between
    switching points.
    That's better;-)
  5. I got it, it appears that the Vh parameter plays two roles here.
    - numbers creates arc intersection, much like an arc-cardinal function
    which can form an arc wave in the load effect of the switch. Setting
    the Vt and Vh -0..-1 sets the arc and offset for the Vt. I guess one
    could use that to make selectable raise/fall rates.
    Using positive numbers does the OFFSET of the Vt (trigger). This means
    If i would to do this, Vh = 1, that would put the Vt at Vt+1 and Vt-1
    etc, which makes sense. but the help file does not explain this to you.
    Jamie
  6. Fred Abse
    Fred Abse Guest
  7. Fred Abse
    Fred Abse Guest
    It actually does explain it, just not very well.
    See the PDF I posted to a.b.s.e, which illustrates the various modes as
    plots of switch impedance versus control voltage.
