Hysteresis Comparator Methods
Discussion in 'Electronic Design' started by D from BC, Jan 3, 2007.
  1. D from BC
    D from BC Guest
    I've seen various hysteresis circuits in app notes such as:
    http://pdfserv.maxim-ic.com/en/an/AN3616.pdf
    I'm not familiar with this method:
    The signal is applied to 2 comparators (no feedback) which are
    connected to a D type latch.
    (Longer discription by request.)
    One benefit I see is that both comparators can get clean stable
    references.
    Anybody familiar with the drawbacks of the 2 comparator D latch
    combo to make a hysteretic comparator?
    Is this a vastly superior circuit compared to what's seen in app
    notes?
    D
  2. John  Larkin
    John Larkin Guest
    This appnote is seriously bogus, in that it totally ignores the
    time-domain aspect of the positive feedback. Figure 7 is especially
    pernicious. Unless very carefully thought out, including consideration
    of the slew rate and noise characteristics of the input signal, the
    conventional hysteresis circuit can propagate glitches contrary to its
    claimed bahavior.
    This appnote is a great example of simplistic, intuitive analysis
    that's just wrong.
    This can be a lot better, because there's no delay coming back around
    into a positive-feedback node, and because the comparator prop delays
    are effectively pipelined... everything flows left-to-right. The
    comparators still have to be well behaved and well characterized,
    specifically to have fairly symmetric rising and falling edge prop
    delays. But this configuration has fewer screwup modes.
    The other nice thing here is that the two comparator references can be
    programmed with DACs, allowing thresholds and hysteresis to be under
    software control. I use this configuration in my tachometer
    conditioning modules, and it's very flexible.
    John
  3. Jim Thompson
    Jim Thompson Guest
    Then there's the optimum method I devised in my MC1650/51 design in
    the mid '60's ;-)
    ...Jim Thompson
  4. John  Larkin
    John Larkin Guest
    Hysteresis internal to ICs can be a lot better, because you can
    localize the positive feedback into a very tight, single-pole loop.
    The HC14 type schmitts are apparently immune from teasing, too.
    Opamps often make better comparators than comparators, because they
    have one dominant pole and don't store as much information as the
    usual fast-multistage comparator topology.
    It's funny that the common comparator-plus-hysteresis circuit is
    almost universally taught as being a clever thing, taught by people
    who don't understand it.
    John
  5. Genome
    Genome Guest
    One thing I don't understand is why you Old Blokes bolloxed on about
    comparators with hysteresis and then gave us comparators with
    hysterectomies...... and we still have to deal with them.
    DNA
  6. Jim Thompson
    Jim Thompson Guest
    The MC1650/51 has BALLS ;-)
    ...Jim Thompson
  7. D from BC
    D from BC Guest
    in message
    about
    DNA
    Great! Looks like this cct. is a "sports car" of hysteretic
    compartors.
    I'm now more suspicious of app notes. Trust nothing. :)
    Got curious and looked up the MC1650.. Dual A/D converter??..
    Huhhh...Still have alot to learn.. :) Internally it's in the
    design "ball park" of interest.
    Op amps make better comparators!! Looks like I picked up a
    myth..In my internet travels, I recall reading that comparators
    are best in comparator applications..
    I haven't yet compared op-amp/comp internals and specs.
    Just blindly running on rumour..
    It's a good thing I don't design life support systems :)
    My next move is to take a look at the various IC's containing a
    combo of op amps (or comparators) and a D latch to make a
    hysteretic comparator.
    CMOS would be nice..
    Thanks for the verification..
    D
  8. Genome
    Genome Guest
    Oh Great
    What's the point of having balls if you haven't got the cock to deliver it?
    I will not mention the sexual aspect of this stuff........ Mr pico second.
    Us thickos want a comparator where we can set the up and down stuff about
    the somewhere else without using our branes.
    DNA
  9. D from BC
    D from BC Guest
    "Jim Thompson" <>
    wrote in
    message news:...
    Oh Great
    deliver it?
    pico second.
    stuff about
    DNA
    Talking about picoseconds...
    I recently came across this speedy op amp with a hysteresis
    control pin.
    http://www.analog.com/UploadedFiles/Data_Sheets/ADCMP566.pdf
    Interesting but wayyy too fast.
    Slower variants are available.
    My app specs are 200nS prop delay and 100mV hysteresis.
    D
  10. Jim Thompson
    Jim Thompson Guest
    I didn't name it. Back in those days Motorola had a department that
    did data sheets. I think the name derived from the 64-wide version I
    made for WPAFB for a flash converter.
    Yep. My 1965 speed numbers compare favorably with today's designs.
    I think it's a myth too.
    I've done several comparator plus D-latch (or even S-R) versions in
    CMOS.
    But they're custom ASIC's.
    ...Jim Thompson
  11. Zak
    Zak Guest
    There's always the 555 :)
    Thomas
  12. Guest
    I'm not sure how well the circuit with the mosfet steering will work.
    At some point, both fets will be on.
    I'd like the longer description.
  13. D from BC
    D from BC Guest
    In regards to using the 555 as a hysteresis comparator....
    The 555 is a great suggestion.
    I'm somewhat stuck using those internal resistors.
    But that might turn out ok...Will be checking specs.
    Nationals LinMos sounds like an improvement to the 555.
    It's one of the few IC's I know of with comparators and a latch.
    D
  14. D from BC
    D from BC Guest
    As requested, longer description for 2 comparator & latch cct to
    make a hysteresis comparator.
    1) Apply same signal to + on one comparator and - on the other.
    2) Apply voltage references to remaining inputs
    3) The "valley" comparator output connects to D and reset of the
    latch
    4) The "peak" comparator output connects to Clk and Set of the
    latch
    (Even longer description by request :) )
    Kinda like the 555.
    D
  15. Guest
    Which comparator is peak and valley. [Non-inverting and inverting?] Do
    I need to know what is dominant (set versus reset, etc.).
    I really don't like a comparator driving the CLK unless the rise/fall
    times are known to be fast enough not to cause problems.
    The other thing to consider is many circuits these days run
    synchronous, so the comparator can just be sampled with a DFF based on
    the master clock. I'm not sure if I'm explaining this well.
  16. D from BC
    D from BC Guest
    As requested..
    Updated description for the 2 comparator&D type latch hystersis
    comparator cct.
    A signal is applied to + input of a comparator. This is the
    "peak" comparator. It's output connects to Clk and Set of the
    latch. The - input gets a ref voltage.
    Same signal is applied to the - of another comparator.
    This is the "valley" comparator and its output connects to D and
    reset of the latch. The + input gets a ref voltage.
    For conserns of comparators driving latches:
    There's comparators with 1.2nS rise and fall times..
    Hopefully good enough...
    In my original post, I mentioned that I'm not familiar with this
    means of creating a hysteretic comparator..
    I haven't thought about the timing to the latch yet.
    I'll be examining this circuit further once I've eliminated
    other competing methods.
    About the sampled comparator& mater clock...
    Sorry, too foggy for me..dunno..
    I seen comparators with build in hold functions..
    D
  17. John  Larkin
    John Larkin Guest
    You can do the same thing with a simple SR latch (cross-coupled NAND
    gates) if you get the comparator polarities right.
    If upper comparator says sig>hilim, set the latch.
    If lower comparator says sig<lolim, clear it.
    In the middle, leave it alone.
    John
  18. Jim Thompson
    Jim Thompson Guest
    A variety of noise-blanking circuits using S-R Flops or the 555
    equivalent are shown in an old posting at....
    http://analog-innovations.com/SED/NoiseBlank.pdf
    I used a device equivalent of the last circuit to "shield" automotive
    ignition pickups from spark noise in 1968.
    ...Jim Thompson
  19. D from BC
    D from BC Guest
    Conserning use of comparators and SR latchs to make a hysteresis
    comparator..
    I'm keeping an eye on that SR latch idea..
    The SR latch has that illegal input state (race condition).
    My spec is 100mV of hysteresis and this circuit is part of a
    smps controller..
    Could be like finding a quiet spot in a noisey dance club :)
    I suspect as hysteresis approachs 0 there's more probability
    that the SR latch gets simultaneous S and R signals due to noise
    presented to the comparators. Just getting scared by this quirk,
    but I won't rule it out yet..
    I had to review my latch operation and found:
    http://www.allaboutcircuits.com/vol_4/chpt_10/4.html
    Which describes the D latch without illegal states.
    For choice of latch in the circuit...
    Perhaps SR is good for wide hystersis and clean signals and D
    latch for small hysteresis and dirty signals??
    D
  20. D from BC
    D from BC Guest
