Huskyvarna radio ear defenders
Discussion in 'General Electronics Discussion' started by Neptune82, Sep 8, 2017.
  1. Neptune82
    Neptune82
    13
    Sep 8, 2017
    Hello everyone. I'm new here and I hope that this is the correct place to post. So I purchased these radio ear defenders for my work at a not too cheap price of 100euro and I have to say the build quality is great I'm really happy with that part . My main problem is the volume of the radio and the aux output when I plug in my phone is extremely low. I understand this is how they are made because of the db exposure limits .basicly there's 1 button in the middle and that controlles the volume and there are 4 levels after pressing it the 4th time the volume then resets back to the lowest level. I mean u can hear the radio ok but if u want to listen to music from your phone the volume is even lower. Is there anything one could do to perhaps modify them somehow to get the volume a couple of notches higher? I have no idea with this kind of thing but perhaps one of u guys can help. I will post a pic and if more info is needed I can post a link . Many thanks guys and girls
    www.husqvarna.com/uk/parts-accessories/hearing-protection/hearing-protection-with-fm-radio/578274901/
  2. Audioguru
    Audioguru
    3,480
    740
    Sep 24, 2016
    When they designed the headphones they did not know that you phone has a low output level.
    To modify them we need to know if they have an internal amplifier then we need a schematic of it. Then you need an electronic expert to do the modification because the parts are tiny.
    Neptune82 likes this.
  3. Neptune82
    Neptune82
    13
    Sep 8, 2017
    Thank u so much for the reply
    The link I posted was the only info I have .would u have a suggestion how I would find it out if they have a amp? Or maybe I could somehow increase the output on my phone? Many thanks
  4. Braeden Hamson
    Braeden Hamson
    225
    13
    Feb 18, 2016
  5. Neptune82
    Neptune82
    13
    Sep 8, 2017
    I think they are made to have a lower volume because in the end they are ear defenders but the radio is not loud and when I plug my Samsung phone in it's much quieter!! So I plugged them into my pc and I was able to increase the volume considerably more
  6. Braeden Hamson
    Braeden Hamson
    225
    13
    Feb 18, 2016
    Screw the $40 stuff, here's an $8 bit from eatafruit:
    https://www.adafruit.com/product/987
    If you bought that you could get a very small enclosure for it and, a small lithium cell & charge/protector circuit, as well as a potentiometer to adjust the volume. You could also just use 2 or 3 1.5 AA or AAA (this would all depend on how long you want it to run for and how big you want the final product to be.)
  7. Neptune82
    Neptune82
    13
    Sep 8, 2017
    I wish I had the skill to do that however I have no clue ! Would this item work ?
    Neoteck Headphone Amplifier Portable 3.5mm Audio Rechargeble HiFi Earphone Headphone Amplifier with Lithium Battery and Aluminum Matte Surface Ideal for MP3 MP4 Phones Digital Players and Computers https://www.amazon.co.uk/dp/B01IHGWGDM/ref=cm_sw_r_cp_apa_pjTSzbA463R4R
  8. Braeden Hamson
    Braeden Hamson
    225
    13
    Feb 18, 2016
    Yeah that's what you're after, and a good price too! I doubt you could get a cheaper one if you DIY.
  9. Neptune82
    Neptune82
    13
    Sep 8, 2017
    Beanden do u think that would increase the volume somewhat ? Thanks
  10. Audioguru
    Audioguru
    3,480
    740
    Sep 24, 2016
    The Adafruit speaker amplifier will not work with headphones unless you replace the entire cable of the headphones because each amplifier is BTL. The headphones cable has a common ground for each channel.
    The Neoteck headphones amplifier produces fairly low 40mW into 16 ohms but if your headphones are 32 ohms then the power will be only about 20mW. The headphones spec's do not say the impedance so the volume might not be loud enough. The headphones reduce but do not eliminate the loud background noise so you probably need them to be fairly loud.
    Braeden Hamson likes this.
  11. Braeden Hamson
    Braeden Hamson
    225
    13
    Feb 18, 2016
    That's interesting, you can't connect the common ground to the amp ground? Why not?
  12. Neptune82
    Neptune82
    13
    Sep 8, 2017
    Please can I just add that the volume does not have to be so loud that you can't hear the outside world, But just that you can clearly hear .perhaps a 20% increase. I know the headphones can go louder because I plugged them into my pc,s Logitech system and was able to turn up the volume significantly.. But for some reason when connecting my phone the max level is verry low. However the built in radio volume is better than when plugged in to my phone.
    When I plug a normal pair of headphones into my phone the volume is more than loud enough
  13. Braeden Hamson
    Braeden Hamson
    225
    13
    Feb 18, 2016
    I really don't see why an external amp, like the one you showed, wouldn't work. IMO buy it, if it doesn't work return it. (Although from my understanding modifying the external amp, if it were too quiet, wouldn't be extremely difficult.)
  14. Neptune82
    Neptune82
    13
    Sep 8, 2017
    Well I ordered the one from link and it comes today so I will update
  15. Audioguru
    Audioguru
    3,480
    740
    Sep 24, 2016
    Headphones are wired with a left signal wire, a right signal wire and a ground wire that is common to both left and right. But the Adafruit amplifier and many more amplifiers that operate from a low supply voltage including most car radios have both wires of each speaker driven with signals called BTL. It effectively doubles the signal voltage and doubles signal current producing almost 4 times the power.
    You would need to pick left and right outputs that are in phase (the other two speaker outputs have reversed phase and are outputs so they must never be grounded), add coupling capacitors to block DC and find a ground on the amplifier somewhere to connect to the headphones.
  16. Neptune82
    Neptune82
    13
    Sep 8, 2017
    Hi guys amp arrived works perfect. Increase of volume 10fold
  17. Neptune82
    Neptune82
    13
    Sep 8, 2017
    But the built in radio volume is not affected
  18. Neptune82
    Neptune82
    13
    Sep 8, 2017
    The only way to adjust the radio volume is by the headset it's self
  19. Audioguru
    Audioguru
    3,480
    740
    Sep 24, 2016
    Which amplifier works well? Adafruit or Neoteck?
  20. Neptune82
    Neptune82
    13
    Sep 8, 2017
    The neoteck works super .But as I said it has no effect at all on the built in radio volume
