Huntron Tracker?
Discussion in 'Electronic Repair' started by Stephanie, Nov 18, 2007.
  1. Stephanie
    Stephanie Guest
    How useful do y'all find the Huntron Tracker (ie, the 2000 model) in
    diagnosing circuits? I have need to troubleshoot power circuits and I've
    found that diagnosing triacs and such with power off is difficult.
    Does the Tracker really make diagnosing such components easier?
    Thanks.
  2. James Sweet
    James Sweet Guest
    While I've never used a Tracker, what's difficult about diagnosing triacs?
    Usually when they fail they short. I often use my Cap Wizard to check for
    shorted semis, it greatly reduces the effect of chokes and other semis from
    interfering, though a good capacitor will appear as a short.
  3. JANA
    JANA Guest
    I used to use a Huntron Tracker. This was many years ago. It is very good
    for testing capacitors, and semiconductors.
    There was a signature kit that could be purchased for the Tracker. It was a
    little complicated to use. You would be able to compare generated waveforms
    between two identical circuit boards under test to see where any changes
    have occurred.
    JANA
    _____
    Thanks.
