John said:
Clive Mitchell <
[email protected]> wrote in message
There also are possible effects not mediated by temperature rise,
although the best documented effect, microwave hearing, isn't known
to occur under the conditions described.
As far as I have seen hearing of this a little more than casually,
Pulsed microwave radiation (as in what is usual for those exposed to
land and ship military/aviation radars) has thermal effects - as in
thermal expansion that is normally negligibale except it occurs at rates
to an extent that has acoustic effects that are detected by human hearing
mechanisms.
See
http://arXiv.org/pdf/physics/0102007
A little aluminum foil should fix it . . ..
John
[email protected] John Michael Williams
And it is well enough known among many of those who have to work close
to radar transmitters that this is an actual effect, and it is a warning
sign - it may be not easy to judge whether an exposure resulting in this
effect can cause two worse effects:
1. The microwave radiation cooks the lenses of the eyes - which are
significantly human body organs not closely connected to the bloodstream!
(This damage mode requires a temperature rise to whatever temperature
causes this damage - a temperature rise of at least several degrees C).
2. If the human brain experiences even a small (just a degree or two,
maybe less) temperature rise that occurs within a few seconds, it can
malfunction.
In extreme cases, a radar troubleshooter can get knocked out and stop
breathing and die on the job from his brain (or parts of it) suddenly
warming up a degree or two.
Otherwise, nobody has shown largely-non-disprovable cause for concern
for low level microwave irradiation!
- Don Klipstein (
[email protected])
