HSPICE to PSPICE Conversion
Discussion in 'CAD' started by Gish, Feb 19, 2005.
  1. Gish
    Gish Guest
    Hi Guys
    I have some SPICE code that runs perfectly in HSPICE but will not run
    in PSPICE due to issues with "subcircuit expansion." If there's any
    experts out there who could take a quick look at this and let me know
    what the issue might be I'd appreciate it.
    **** circuit description
    rs in inp 50
    r1 inp vss 1K
    x1 inp inm out vss my_opamp
    rf out inm 100K
    r2 inm vss 1K
    **** parameters section
    **** sources section
    v1 in vss sin(0V 60mV 10x 100ps 0)
    v2 vss 0 dc 0V
    **** specify nominal temperature of circuit in degrees C
    ..TEMP= 60
    **** analysis section
    ..tran 1ns 200ns
    ..END
  2. Chaos Master
    Chaos Master Guest
    19 Feb 2005 12:41:24 -0800: Gish (----> ) ---->
    sci.electronics.cad @
    What's the model for 'my_opamp' subcircuit (subckt)?
    []s
    Chaos Master®, posting from Canoas, Rio Grande do Sul, Brazil - 29.55° S
    / 51.11° W / GMT-2h / 15m .
    "People told me I can't dress like a fairy.
    I say, I'm in a rock band and I can do what the hell I want!"
    -- Amy Lee
    (My e-mail address isn't read. Please reply to the group!)
  3. Gish
    Gish Guest
    Ok,
    I actually figured everything out except for one line...
    E1 out ref in+ in- MAX=5V MIN=-5V opamp_gain
    I'm trying to code a VCVS with maximum and minimum output values, but
    PSPICE rejects the MAX and MIN parts. Any ideas?
  4. Chaos Master
    Chaos Master Guest
    19 Feb 2005 20:25:20 -0800: Gish (----> ) ---->
    I think that PSpice doesn't support MAX and MIN values.
    []s
    -- Amy Lee
    For spammers: , or .
    Those await for your spams!
  5. Jim Thompson
    Jim Thompson Guest
    [snip]
    Here are a few of the operators in PSpice BEHAVIORAL elements:
    LIMIT(x,min,max) result is min if x < min, max if x > max, and x
    otherwise
    MAX(x,y) maximum of x and y
    MIN(x,y) minimum of x and y
    In addition you must use the BEHAVIORAL syntax of the E-source
    So the correct expression for E1 is:
    E1 out ref VALUE = {LIMIT((opamp_gain*V(in+,in-)),MIN,MAX)}
    ..PARAM MAX=5V MIN=-5V opamp_gain=100K
    (Or put the numerics directly in the expression.)
    This is convergence risk using mathematical limits, since they are
    hard, and derivatives don't exist at the limit points.
    I prefer using the TANH expression:
    E1 1 0 VALUE {(tanh(A*V(INP,INN))+1)/2}
    E2 OUT 0 VALUE {V(1,0)*(VP-VN)+VN}
    ..PARAM A=100K ; OpAmp Gain
    ..PARAM VP=+5V ; Positive Limit
    ..PARAM VN=-5V ; Negative Limit
    (Note that exact gain is an interaction between A, VP, and VN (E1
    produces 0 ->1), but I'm still too sleepy this morning to make an
    exact expression :)
    ...Jim Thompson
  6. Jim Thompson
    Jim Thompson Guest
    [snip]
    Are you using PSpice "raw", i.e. without schematic capture?
    Both PSpice Schematics and Capture (gag me with a spoon) have the
    correct netlist TEMPLATE contained within the symbol.
    (Not that I should be one to criticize. I went for MANY years drawing
    schematics with pencil and paper, numbering nodes, hand-typing
    netlists, and batch-loading into Berkeley Spice 2G6 on an old VAX,
    IIRC, 1170. Then I discovered PC's and bought my first 386 for $6K...
    cheap because it was a clone :)
    ...Jim Thompson
  7. Chaos Master
    Chaos Master Guest
    Sun, 20 Feb 2005 10:40:10 -0700: Jim Thompson (---->
    ) ----> sci.electronics.cad @
    I sometimes end up doing this, even though I have 2 schematic editors
    here (LTspice and SIMetrix Intro).
    []s
    -- Amy Lee
