josephkk said:
Maybe, used to be able to "read" HPGL. If you can capture the output
stream sent to the "plotter" maybe i can tell you what is going on.
Ok, didn't have the original plot files anymore but here is one with
noise and the marker at 108.5MHz. Not sure if it'll make it via Usenet:
LB;DF;SC 0, 2144, 0, 2047;VS 10;LT;SP 1;PU;PA 72, 152;PU;PA 72,
779;PD;PA 76, 269;PD;PA 80, 163;PD;PA 84, 152;PD;PA 88, 182;PD;PA 92,
164;PD;PA 96, 227;PD;PA 100, 206;PD;PA 104, 152;PD;PA 108, 296;PD;PA
112, 237;PD;PA 116, 203;PD;PA 120, 152;PD;PA 124, 266;PD;PA 128,
293;PD;PA 132, 233;PD;PA 136, 224;PD;PA 140, 191;PD;PA 144, 152;PD;PA
148, 161;PD;PA 152, 237;PD;PA 156, 304;PD;PA 160, 166;PD;PA 164,
152;PD;PA 168, 180;PD;PA 172, 152;PD;PA 176, 218;PD;PA 180, 152;PD;PA
184, 186;PD;PA 188, 154;PD;PA 192, 204;PD;PA 196, 152;PD;PA 200,
152;PD;PA 204, 251;PD;PA 208, 152;PD;PA 212, 213;PD;PA 216, 161;PD;PA
220, 164;PD;PA 224, 167;PD;PA 228, 154;PD;PA 232, 239;PD;PA 236,
226;PD;PA 240, 152;PD;PA 244, 302;PD;PA 248, 152;PD;PA 252, 195;PD;PA
256, 221;PD;PA 260, 152;PD;PA 264, 259;PD;PA 268, 232;PD;PA 272,
220;PD;PA 276, 156;PD;PA 280, 213;PD;PA 284, 229;PD;PA 288, 152;PD;PA
292, 230;PD;PA 296, 216;PD;PA 300, 188;PD;PA 304, 289;PD;PA 308,
201;PD;PA 312, 255;PD;PA 316, 152;PD;PA 320, 212;PD;PA 324, 152;PD;PA
328, 255;PD;PA 332, 261;PD;PA 336, 283;PD;PA 340, 179;PD;PA 344,
172;PD;PA 348, 152;PD;PA 352, 179;PD;PA 356, 276;PD;PA 360, 176;PD;PA
364, 201;PD;PA 368, 181;PD;PA 372, 152;PD;PA 376, 152;PD;PA 380,
221;PD;PA 384, 152;PD;PA 388, 189;PD;PA 392, 298;PD;PA 396, 212;PD;PA
400, 152;PD;PA 404, 156;PD;PA 408, 256;PD;PA 412, 283;PD;PA 416,
152;PD;PA 420, 265;PD;PA 424, 152;PD;PA 428, 152;PD;PA 432, 192;PD;PA
436, 216;PD;PA 440, 249;PD;PA 444, 152;PD;PA 448, 177;PD;PA 452,
152;PD;PA 456, 257;PD;PA 460, 231;PD;PA 464, 255;PD;PA 468, 245;PD;PA
472, 152;PD;PA 476, 255;PD;PA 480, 164;PD;PA 484, 152;PD;PA 488,
283;PD;PA 492, 152;PD;PA 496, 207;PD;PA 500, 159;PD;PA 504, 152;PD;PA
508, 262;PD;PA 512, 152;PD;PA 516, 169;PD;PA 520, 224;PD;PA 524,
152;PD;PA 528, 152;PD;PA 532, 274;PD;PA 536, 245;PD;PA 540, 152;PD;PA
544, 152;PD;PA 548, 212;PD;PA 552, 194;PD;PA 556, 152;PD;PA 560,
152;PD;PA 564, 306;PD;PA 568, 175;PD;PA 572, 211;PD;PA 576, 250;PD;PA
580, 152;PD;PA 584, 152;PD;PA 588, 152;PD;PA 592, 152;PD;PA 596,
161;PD;PA 600, 187;PD;PA 604, 152;PD;PA 608, 165;PD;PA 612, 208;PD;PA
616, 152;PD;PA 620, 180;PD;PA 624, 152;PD;PA 628, 152;PD;PA 632,
199;PD;PA 636, 152;PD;PA 640, 160;PD;PA 644, 152;PD;PA 648, 152;PD;PA
652, 152;PD;PA 656, 152;PD;PA 660, 184;PD;PA 664, 152;PD;PA 668,
152;PD;PA 672, 152;PD;PA 676, 242;PD;PA 680, 238;PD;PA 684, 152;PD;PA
688, 229;PD;PA 692, 248;PD;PA 696, 270;PD;PA 700, 196;PD;PA 704,
303;PD;PA 708, 204;PD;PA 712, 289;PD;PA 716, 266;PD;PA 720, 259;PD;PA
724, 152;PD;PA 728, 152;PD;PA 732, 217;PD;PA 736, 178;PD;PA 740,
253;PD;PA 744, 213;PD;PA 748, 159;PD;PA 752, 203;PD;PA 756, 252;PD;PA
760, 152;PD;PA 764, 158;PD;PA 768, 188;PD;PA 772, 221;PD;PA 776,
152;PD;PA 780, 152;PD;PA 784, 210;PD;PA 788, 297;PD;PA 792, 315;PD;PA
796, 152;PD;PA 800, 230;PD;PA 804, 152;PD;PA 808, 152;PD;PA 812,
152;PD;PA 816, 152;PD;PA 820, 152;PD;PA 824, 152;PD;PA 828, 152;PD;PA
832, 250;PD;PA 836, 269;PD;PA 840, 247;PD;PA 844, 152;PD;PA 848,
233;PD;PA 852, 208;PD;PA 856, 189;PD;PA 860, 167;PD;PA 864, 201;PD;PA
868, 305;PD;PA 872, 240;PD;PA 876, 247;PD;PA 880, 152;PD;PA 884,
152;PD;PA 888, 238;PD;PA 892, 179;PD;PA 896, 152;PD;PA 900, 179;PD;PA
904, 167;PD;PA 908, 200;PD;PA 912, 203;PD;PA 916, 198;PD;PA 920,
152;PD;PA 924, 165;PD;PA 928, 218;PD;PA 932, 152;PD;PA 936, 215;PD;PA
940, 347;PD;PA 944, 241;PD;PA 948, 245;PD;PA 952, 193;PD;PA 956,
200;PD;PA 960, 181;PD;PA 964, 208;PD;PA 968, 265;PD;PA 972, 259;PD;PA
976, 179;PD;PA 980, 256;PD;PA 984, 225;PD;PA 988, 152;PD;PA 992,
170;PD;PA 996, 152;PD;PA 1000, 239;PD;PA 1004, 174;PD;PA 1008, 257;PD;PA
1012, 235;PD;PA 1016, 152;PD;PA 1020, 152;PD;PA 1024, 152;PD;PA 1028,
152;PD;PA 1032, 175;PD;PA 1036, 205;PD;PA 1040, 249;PD;PA 1044,
152;PD;PA 1048, 152;PD;PA 1052, 155;PD;PA 1056, 198;PD;PA 1060,
223;PD;PA 1064, 152;PD;PA 1068, 170;PD;PA 1072, 224;PD;PA 1076,
152;PD;PA 1080, 233;PD;PA 1084, 275;PD;PA 1088, 152;PD;PA 1092,
202;PD;PA 1096, 152;PD;PA 1100, 206;PD;PA 1104, 317;PD;PA 1108,
256;PD;PA 1112, 152;PD;PA 1116, 161;PD;PA 1120, 152;PD;PA 1124,
152;PD;PA 1128, 281;PD;PA 1132, 209;PD;PA 1136, 152;PD;PA 1140,
152;PD;PA 1144, 265;PD;PA 1148, 152;PD;PA 1152, 166;PD;PA 1156,
185;PD;PA 1160, 192;PD;PA 1164, 152;PD;PA 1168, 176;PD;PA 1172,
152;PD;PA 1176, 255;PD;PA 1180, 159;PD;PA 1184, 172;PD;PA 1188,
185;PD;PA 1192, 152;PD;PA 1196, 239;PD;PA 1200, 152;PD;PA 1204,
227;PD;PA 1208, 296;PD;PA 1212, 204;PD;PA 1216, 152;PD;PA 1220,
246;PD;PA 1224, 159;PD;PA 1228, 168;PD;PA 1232, 152;PD;PA 1236,
152;PD;PA 1240, 213;PD;PA 1244, 152;PD;PA 1248, 229;PD;PA 1252,
222;PD;PA 1256, 152;PD;PA 1260, 274;PD;PA 1264, 152;PD;PA 1268,
188;PD;PA 1272, 152;PD;PA 1276, 320;PD;PA 1280, 152;PD;PA 1284,
238;PD;PA 1288, 191;PD;PA 1292, 232;PD;PA 1296, 155;PD;PA 1300,
211;PD;PA 1304, 216;PD;PA 1308, 152;PD;PA 1312, 186;PD;PA 1316,
225;PD;PA 1320, 187;PD;PA 1324, 161;PD;PA 1328, 295;PD;PA 1332,
258;PD;PA 1336, 152;PD;PA 1340, 205;PD;PA 1344, 152;PD;PA 1348,
152;PD;PA 1352, 167;PD;PA 1356, 152;PD;PA 1360, 183;PD;PA 1364,
179;PD;PA 1368, 262;PD;PA 1372, 195;PD;PA 1376, 262;PD;PA 1380,
239;PD;PA 1384, 152;PD;PA 1388, 152;PD;PA 1392, 152;PD;PA 1396,
160;PD;PA 1400, 152;PD;PA 1404, 258;PD;PA 1408, 259;PD;PA 1412,
152;PD;PA 1416, 184;PD;PA 1420, 210;PD;PA 1424, 227;PD;PA 1428,
268;PD;PA 1432, 329;PD;PA 1436, 276;PD;PA 1440, 229;PD;PA 1444,
201;PD;PA 1448, 152;PD;PA 1452, 223;PD;PA 1456, 267;PD;PA 1460,
204;PD;PA 1464, 211;PD;PA 1468, 201;PD;PA 1472, 192;PD;PA 1476,
242;PD;PA 1480, 152;PD;PA 1484, 193;PD;PA 1488, 184;PD;PA 1492,
167;PD;PA 1496, 185;PD;PA 1500, 201;PD;PA 1504, 202;PD;PA 1508,
203;PD;PA 1512, 152;PD;PA 1516, 156;PD;PA 1520, 185;PD;PA 1524,
295;PD;PA 1528, 259;PD;PA 1532, 152;PD;PA 1536, 152;PD;PA 1540,
247;PD;PA 1544, 152;PD;PA 1548, 224;PD;PA 1552, 189;PD;PA 1556,
167;PD;PA 1560, 152;PD;PA 1564, 220;PD;PA 1568, 152;PD;PA 1572,
167;PD;PA 1576, 152;PD;PA 1580, 152;PD;PA 1584, 152;PD;PA 1588,
152;PD;PA 1592, 152;PD;PA 1596, 152;PD;PA 1600, 198;PD;PA 1604,
152;PD;PA 1608, 152;PD;PA 1612, 205;PD;PA 1616, 152;PD;PA 1620,
152;PD;PA 1624, 152;PD;PA 1628, 152;PD;PA 1632, 207;PD;PA 1636,
158;PD;PA 1640, 152;PD;PA 1644, 211;PD;PA 1648, 176;PD;PA 1652,
152;PD;PA 1656, 188;PD;PA 1660, 152;PD;PA 1664, 152;PD;PA 1668,
239;PD;PA 1672, 216;PU;PU;SR 1.119, 1.758;PA 940,
347;PU;CP-0.110,-0.140;PD;CP-0.170, 0.080;PD;CP 0, 0.110;PD;CP 0.170,
0.080;PD;CP 0.220, 0;PD;CP 0.170,-0.080;PD;CP
0,-0.110;PD;CP-0.170,-0.080;PD;CP-0.220, 0;PU;CP 0.110, 0.140;LT;SP
2;PU;PA 72, 152;PD;PA 1672, 152;PD;PA 1672, 1752;PD;PA 72, 1752;PD;PA
72, 152;PU;PA 72, 312;PD;PA 1672, 312;PU;PA 1672, 472;PD;PA 72,
472;PU;PA 72, 632;PD;PA 1672, 632;PU;PA 1672, 792;PD;PA 72, 792;PU;PA
72, 952;PD;PA 1672, 952;PU;PA 1672, 1112;PD;PA 72, 1112;PU;PA 72,
1272;PD;PA 1672, 1272;PU;PA 1672, 1432;PD;PA 72, 1432;PU;PA 72,
1592;PD;PA 1672, 1592;PU;PA 1512, 1752;PD;PA 1512, 152;PU;PA 1352,
152;PD;PA 1352, 1752;PU;PA 1192, 1752;PD;PA 1192, 152;PU;PA 1032,
152;PD;PA 1032, 1752;PU;PA 872, 1752;PD;PA 872, 152;PU;PA 712, 152;PD;PA
712, 1752;PU;PA 552, 1752;PD;PA 552, 152;PU;PA 392, 152;PD;PA 392,
1752;PU;PA 232, 1752;PD;PA 232, 152;PU;SP 1;PU;PA 72, 1752;LT 2,
2.270;PD;PA 1672, 1752;PU;SP 2;PU;PA 10, 2001;LT;DR 1, 0;SR 1.119,
1.758;LBREF LEVELPU;PU;PA 442, 2001;LT;DR 1, 0;SR 1.119,
1.758;LB/DIVPU;PU;PA 10, 82;LT;DR 1, 0;SR 1.119, 1.758;LBSTART
0.000HzPU;PU;PA 910, 82;LT;DR 1, 0;SR 1.119, 1.758;LBSTOP 200 000
000.0LB00HzPU;PU;PA 10, 14;LT;DR 1, 0;SR 1.119, 1.758;LBAMPTD
-10.0dBmPU;SP 1;PU;PA 10, 1929;LT;DR 1, 0;SR 1.119,
1.758;LB0.000dBmPU;PU;PA 442, 1929;LT;DR 1, 0;SR 1.119,
1.758;LB10.000dBPU;PU;PA 838, 2001;LT;DR 1, 0;SR 1.119, 1.758;LBMARKER
108 500 000LB.000HzPU;PU;PA 838, 1929;LT;DR 1, 0;SR 1.119,
1.758;LBMAG(R) -87.777LBdBmPU;LT;PU;PA0,0;SP0;
