HP Printer doesn't work anymore
Discussion in 'Troubleshooting and Repair' started by S4lad, Mar 23, 2018.
  1. S4lad
    S4lad
    13
    Mar 22, 2018
    Hello, I have an HP Photosmart Plus Series Printer (B210a) , and when I wanted to replace the Ink Cartridge , it gave me the error 0xC19A0003(Ink System Failure). I restarted it multiple times, removed and placed the printer head multiple times back but it didn't help. So I fully reset the printer, now everytime I start it up it tells me that it cant detect the printerhead...
  2. davenn
    davenn Moderator
    13,765
    1,920
    it sounds like you forgot to remove one or more of the plastic protection tabs off the cartridges. Either that or you are not installing the cartridges correctly
  3. S4lad
    S4lad
    13
    Mar 22, 2018
    I tried it without cartridges, nothing happens,still the same error
  4. Alec_t
    Alec_t
    2,928
    797
    Jul 7, 2015
    Do you have a genuine HP cartridge?
  5. S4lad
    S4lad
    13
    Mar 22, 2018
    Yes
  6. davenn
    davenn Moderator
    13,765
    1,920
    well it isn't likely to initialise without the cartridges
    My HP and my Epson have very specific cartridge changing steps for both the removal and installation
    if those steps are not followed exactly, then it isn't likely to initialise properly
    Soooooooooooooo .... what happens if you put the old cartridges back in ? ..... FOLLOW THE STEPS :) :)
    if it doesn't work and initialise and just tell you the ink is low, then it is likely that you haven't followed the steps correctly
  7. dave9
    dave9
    1,003
    264
    Mar 5, 2017
  8. S4lad
    S4lad
    13
    Mar 22, 2018
  9. S4lad
    S4lad
    13
    Mar 22, 2018
    I don't have these anymore...
  10. S4lad
    S4lad
    13
    Mar 22, 2018
    On every start it just gives me: "Printhead Missing;Lift the latch,re-seat the Printhead and then lower the latch", i tried that multiple times and I can't get past this error
  11. kellys_eye
    kellys_eye
    4,275
    1,146
    Jun 25, 2010
    Take the printhead out and check that the connections between the head and carriage are perfectly clean, undamaged etc and look for any breakages in the ribbon connector.
    There is a 'physical' fault here and it's either with the head or the ribbon OR the printhead really IS dud and will require replacement (actually, dump the printer as a new one is always cheaper than a spare printhead...)
  12. S4lad
    S4lad
    13
    Mar 22, 2018
    Yeah, I thought about buying a new one.. this one is pretty old
