HP Pavilion PC - identify part please
Discussion in 'Electronic Repair' started by TYTWAD, Sep 28, 2003.
  1. TYTWAD
    TYTWAD Guest
    Have HP Pavilion PC model 6643 with combination board for modem, sound etc.
    Part number of board is 5184-3924. Lighting zapped C98 and C100. Can any one
    identify these SM parts and value??? they are caps but have no idea of
    ratings. Thanks Richard
  2. JURB6006
    JURB6006 Guest
    I hate those friggin things, and it is probably fried. Good.
    I recommend you just buy and install another MODEM and a soundcard and get it
    over with. If it's an older PC, try to get a hardMODEM for it.
    I don't care how much of a tightwad you are, nobody troubleshoots this stuff to
    component level. Time is money and it simply isn't worth the time. What's more
    I'll bet you dollars to doughnuts that there is alot more wrong with that card
    than those teensy caps, whatever chips/transistors etc they are connected to
    are probably fried as well.
    You don't need the exact same card from HP, just go to the local PC joint and
    you can get a MODEM for $10. You can use a used soundcard that shouldn't cost
    more than $5.
    Just in case.......if it has an Aztech chipset and the drivers are already on
    your PC, I got one from a PB Pentium system you can have for $10+ship, but even
    at that it's probably better to just get them locally even new.
    JURB
