M
Michael
Hi, all. I have an HP P1110 21" monitor with a weird high-voltage
problem. Turn it on, great pic. After about 30 seconds, it blooms and
gets very out of focus, then the neon flashover lamp near the flyback
arcs over, there's a loud pop, and the pic disappears. A second later,
it comes back on looking normal, and then the cycle repeats.
When I first got it, I suspected some solder joints around the board in
the corner, where the HV setting pot is. I soldered them and the darned
thing worked for a couple of months! Then it started doing it again, and
now nothing I do will stop it. It doesn't seem to be mechanically
influenced the way a bad connection would be. Tapping hard around the
area has no effect.
Is it just a bad flyback? I hate to spend for one if that's not the
problem. Anybody run into this one before?
I know these monitors have an issue with being overly bright. This one
was a bit like that when I got it, but turning down the screen solved
that, and the brightness hasn't varied, except when the problem flares
up and it blooms and dims.
Thanks for any advice.
Sincerely,
Michael
area has no effect.
Sincerely,
Michael
