HP Laserjet 1020 printer
B
Bob Parker
From the day I bought it, my Laserjet 1020 has made a fairly loud
clunk-clunk-clunk noise while the paper feed rollers are rotating.
Apart from that, it works perfectly OK.
Does anyone else here have one of these printers, and does it also
make that annoying noise?
P
Phil Allison
"Bob Parker"
** Must be Bill & Dave turning in their graves...
....... Phil
Jeff Liebermann
I have several located at various customers. Hardly any noise when
printing. Something is wrong with yours. My guess(tm) is that the
noise is coming from the toner cartridge. See if you can borrow a
different cartridge for testing. You can sometimes isolate the source
of the noise with a stethoscope.
Also see:
http://www.fixyourownprinter.com
HP printer forums
http://www.tek-tips.com/threadminder.cfm?pid=697
HP IT Resources (See printers forum)
http://forums1.itrc.hp.com/service/forums/categoryhome.do?categoryId=219
http://itrc.hp.com
A
Allodoxaphobia
comp.periphs.printers
comp.sys.hp.hardware
B
Bob Parker
Also see:
HP printer forums
http://itrc.hp.com
Thanks for all the info Jeff. That's exactly what I wanted to know.
Much appreciated!
Cheers
B
Bob Parker
...... Phil
From having their logo which used to signify top quality professional
test gear stuck on cheap Chinese printers...?
P
Phil Allison
"Bob Parker"
"Phil Allison"
** As the popular, modern Greek / Australian philosopher, Effie would say:
" How embarrassment ..... "
......... Phil
B
Bob Parker
........ Phil
Know what you mean. :)
For the edification of anyone reading this, I tore the printer
apart and found the culprit: a missing tooth on the plastic gear which
drives the paper output rollers.
To replace it, the nice HP people would like me to replace the
entire fuser assembly it's part of (slightly cheaper than a new
printer). Stupid me waited until the warranty expired before I checked
it, didn't I?
But it still works OK, so I can't complain.
H
Homer J Simpson
printer)
Try for another printer to rob parts from?
_____ _ _
|_ _| | | | |
| | __ _ _ __ ___ | |__| | ___ _ __ ___ ___ _ __
| | / _` | '_ ` _ \ | __ |/ _ \| '_ ` _ \ / _ \ '__|
_| |_ | (_| | | | | | | | | | | (_) | | | | | | __/ |
|_____| \__,_|_| |_| |_| |_| |_|\___/|_| |_| |_|\___|_|
__ ____
/ _| | _ \
___ | |_ | |_) | ___ _ __ __ _
/ _ \| _| | _ < / _ \| '__/ _` |
| (_) | | | |_) | (_) | | | (_| |_
\___/|_| |____/ \___/|_| \__, (_)
__/ |
|___/
B
boardjunkie
it, didn't I?
You can fix the gear if its easy enough to take out. Clean off any
grease with a solvent that won't attack the material the gear is made
of (who knows what that might be). Denatured alcohol should be OK. Fill
in the "blank spot" with a good epoxy or JB weld. Let it cure for a
copule days and hand cut a new tooth into the epoxy with miniature
"jewelers" files. Might take a while but it can be done.
B
Bob Parker
Not a bad idea. I can't afford to have the printer unusable for
amount of time it would take to try the idea of creating a new tooth
from epoxy. :-(
Thanks!
