HP / Agilent 8160A Pulse Generator
Discussion in 'Electronic Equipment' started by Peter Werzer, Nov 9, 2005.
  1. Peter Werzer
    Peter Werzer Guest
    Hey,
    I have a puls generator mentioned above.
    The settings for the impuls frequency and width and so
    on work fine but there is a problem.
    If I set the the impedance on 10kOhms I
    only get 4V amplitude instead of 19.99V and at 50 Ohm there is
    only 200mV instead of 9.99V. I have not found anything to change
    this behavior! Also there is shown an error message "PARAM" if I press
    the High Level (HIL) botton or the Low Level (LOL)
    botton.
    The DC-voltage is on the 0-line at about -7.5V and
    oscillate 300mV up and down.
    If there is someone who knows what is wrong please let me know!
    best regards
    Peter
  2. carneyke
    carneyke Guest
    Pete,
    You have a problem with one of the output hybrid modules. If your unit
    is a dual channel option, you have modules to swap. These modules were
    very expensive (made internally by HP) and were a high failure item.
    There are lots of boards to swop if you have a dual channel unit.
    Remember to mark board and dip switch / switch settings. You will have
    to shange setiings if you have a dual channel option and swop boards
    from "A" to"B". Good Luck, Kevin
