HP 8640B and VLF?
Discussion in 'Electronic Equipment' started by Henry Kolesnik, Nov 22, 2003.
  1. I just acquired an HP 8640B and now I'd like to get rid of my HP 606A but I
    need to go below 500 KHz. I wonder if anyone has had any experience with
    the HP 11710A or B that they'd care to comment on. I'd also like to know if
    there's any other reasonably priced LF sig gen that's stable and has a
    calibrated output that I should consider as $150.00 for an HP 11710 seems
    kind of high when you can find HP 8640Bs for around $200.
    tnx
    hank wd5jfr
  2. Tweetldee
    Tweetldee Guest
    You should be able to find a copy of the HP 650 series generator on Ebay or
    at a local surplus store or hamfest. They cover 10 Hz to 10 Mhz, and a
    calibrated attenuator. Good instrument.
    Tweetldee
    Tweetldee at att dot net (Just subsitute the appropriate characters in the
    address)
    Never take a laxative and a sleeping pill at the same time!!
  3. Or a TS-382 military test set. ;-)
    I say, the boy is so stupid that he tried to make a back up copy of his
    hard drive on the Xerox machine!
    Michael A. Terrell
    Central Florida
