HP 54121T + 54121A
Discussion in 'Electronic Equipment' started by Richard Klingler, Jul 23, 2007.
  1. Evnin'
    I'm looking for a refurbished scope and came across the 54121T + 54121A
    which are sold quiet cheap and offer high sample rates...
    Is this combination only meant for RF designs or high speed digital
    circuits as the 54121A is 50 Ohms only...
    Or is there a test module where I can capture higher voltages also
    with higher impedances?
    Sorry for asking...but totally unfamiliar with all those different
    HP Agilent 54xxx scopes (o;
    But I'm just looking for an affordable high speed solution to debug
    my FPGA designs mainly...
    thx in advance
    rick
  2. No, it offers high bandwidth at very low sample rates
    You could use external 50 Ohm attenuators (20 dB = divide by 10 voltage-wise)
    or FET probes for higher impedance. These cost a lot and are
    limited to a few GHz of bandwidth.
    There are also passive probes for 50 Ohm loads( TEK P6056, P6156)
    but they may present 50 Ohm to 5K to the DUT depending on
    attenuation factor.
    Use Modelsim XE ;-)
    These 54xxx scopes are for repetitive signals only. You can use them
    for characterizing rise/fall times or generate eye diagrams on
    Xilinx Rocket I/Os, but not for general debugging because you
    cannot see single events. Triggering in the sense of a Tek 475
    is nonexistant, let alone in logic analyzer style.
    I'd propose a HP16500C logic analyzer for FPGA debugging with
    at least one state/time analyzer card and one or two
    scope cards with 250 or 500 MHz BW. There exists an older
    scope as a 2 card set(time base and aquisition) that is complete crap.
    Or you might choose a non-plugin-version that would be easier to operate
    than the touch screen menue system.
    Single shot scopes with 1GHz or more BW will cost an arm & a leg.
    If you insist in 54xxx, I think the sweet spot is 54750 / 54751
    and 54701 probes. And don't kill those PC3.5 connectors with
    cheap/defective SMAs.
    regards, Gerhard
  3. Hello list , we are looking for following test equipment, used w/ deep
    discounts preferred.
    Thanks in advance,
    Ben Youngblood
    networkinghardware.net
    Tektronix tds2014b
    Rohde Schwarz cts55
    Agilent 11945a
    ENI 550l
    Fluke 5200a
    Amplifier Research 200l
    Marconi 2955b
    Agilent 8703b
    Microtel MSR904A
    Agilent 8485a
    Microtel MSR904A
    Marconi 2955b 3
    Agilent 8703b 1
    Anritsu 68077b
    Anritsu 68077c
    Anritsu 68247b
    Agilent 8722a
    Agilent 8722b
    Agilent 8722c
    Agilent 8722d
    Agilent e8362a
    Agilent 54845a
    Tektronix tds694c
    Lecroy wp960xl
    Agilent 8564e
    Agilent 8574a
    Agilent e8267d
    Kind Regards,
    Ben Youngblood
    http://www.networkinghardware.net
    DCR is your one stop solution for Datacom, Networking & Telecom
    hardware, new and used at 60% to 90% off list.
    We buy & sell 3com, ADC/Kentrox, Adtran, Ascend/Lucent, AVAYA,
    Cisco, Enterasys/Cabletron, Extreme, JUNIPER NETWORKS, Larscom,
    Lucent PSAX, N.E.T. Promina & IDNX, Nortel, Cisco/Stratacom,
    Newbridge,
    Verilink, Nortel Networks, TELLABS and more...
    Over 5,000 items in stock. Please visit out our website @
    SOME INVENTORY ON-LINE. PLEASE CALL
    OR REPLY FOR UPDATED OR INCOMING INVENTORY
    Ben "Benny" Youngblood networkinghardware.net
  4. Looked at the 54720D now which is available for a good price...
    Would this be a nice choice together with a bunch of 54712A
    and 54701A probes for hobbyist use? Still much cheaper than
    a brand new WJ314...
    cheers
    rick
  5. Looks good. If the price is right..
    Gerhard
