R
R. D. Davis
After taking a rest for several years my HP-5244L frequency counter is
doing something that it shouldn't do at the input stage (or so it
appears). Having no manual for this instrument, any help that anyone
can kindly provide will be greatly appreciated.
When the input sensitivity is set on 10V or 1V, the counter doesn't
respond to input signals. When set to 0.1V sensitivity. the counter
won't display a reading until the signal reaches 6.6Vp-p (measured
when disconnected from the counter). When the 6.6Vp-p sine wave is
applied to the counter, the counter loads it down so that it reads
about 2Vp-p. ...but at least the reading appears to be fairly
accurate.
Is there any particular component known for failing and causing this
problem? It's my guess that the problem's probably something simple
like a leaky capacitor... so, I guess I'll start looking for those
first.
Also, I'm trying to restore an HP-5233L counter, but, alas, not even
the self-checks appear to work; however, all of the tubes in the
display light up, and the neon lights used as decimal points appear to
work, in the right positions. Again, no documentation for this;
however, I do have documentation for a 5223L, which appears to be
slightly different. Any suggestions for first things to check,
besides the power supply? Do most of the things to check for the
5223L apply to the 5233L? What are the similarities/differences?
accurate.
first.
