Yes, that's how I felt too. Anyway, what's done is done.
I just ran two tests... first with LVPS with no load. Second with LVPS plugged onto A12 (but with HVPS removed. The no load test was almost identical to the previous no load test.
Across VR3 = 36.4
Across R18 = 0.0
Across R17 = 45.9
at +156 = 166.5
at +120 = 133.0
at -100 = -95.2
at -15 = -14.8
at +15 = +14.9
at +48 = 48.0
at +5 = 5.0
at +15 Unreg = 27.4
Then with A12 (only) plugged in everything started racing to zero. There was no way to get a real read. I tested two or three points, each after powering down and powering up again... the numbers just clicked downward non-stop.
After that I decided to unplug A12 and see if I got the right readings from the unloaded LVPS. They had moved a little, but not much... normal variance, probably. Still, I think A12 is now a prime suspect. Unfortunate, since it is going to be hard to test.
Across VR3 = 36.4
Across R18 = 0.0
Across R17 = 45.9
at +156 = 166.5
at +120 = 133.0
at -100 = -95.2
at -15 = -14.8
at +15 = +14.9
at +48 = 48.0
at +5 = 5.0
at +15 Unreg = 27.4
