HP 15116A Pulse Inverter
Discussion in 'Electronic Equipment' started by O. P. E., May 11, 2007.
  1. O. P. E.
    O. P. E. Guest
    HP used to build a pulse inverter that would take a pulse and flip it
    to the opposite polarity. It looks to be a simple design, with just a
    single transformer. However, it had a rise time of less than 500 ps.
    http://www.home.agilent.com/upload/cmc_upload/All/15116A-splitter-eng.pdf
    I'm thinking of adding a transformer to a circuit I am building to
    include inversion. Has anyone used this pulse inverter, or anything
    similar? Is it as easy as the circuit diagram makes it appear?
    Finally, does anyone have any recommendations on who would carry these
    types of transformers now?
    Appreciate the feedback.
  2. DaveM
    DaveM Guest
    Yes, it's as simple as the data sheet says. It's nothing more than a simple 1:1
    pulse transformer, and can be wired to invert or not.
    The output pulse risetime is very dependent on the input pulse's risetime. Very
    small pulse widths also.
    Dave M
    MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
    address)
    Life is like a roll of toilet paper; the closer to the end, the faster it goes.
  3. O. P. E.
    O. P. E. Guest
    Thanks for the confirmation. I think I will try a couple of mini-
    circuits transformers. Their bandwidth goes into the GHz, and I was
    going to order some other parts from them. Since I'm not an EE, I am
    tentative about RF circuits, as I know their tends to be some "black
    magic" to get them to work.
