G
Glenn
I have looked at the power supply schematic for the HP 141T with the
intention of improving it, and found something that is very odd (also
found others - maybe another time):
Old one - "neon tube" stabilized (pdf-page 35):
141T Display.pdf
New one - zenerdiode stabilized (pdf-page 10..12):
141T_changes.pdf
(both downloaded from here: http://bama.edebris.com/manuals/hp/141t/ )
The three lower driver and power series regulator transistor base
resistors - to high voltages - bothers me. I would prefer e.g. 100 ohm
to the emitter.
If the output transistors turn off, just for millisecond, the base is
pulled "downward" to the high voltages. The (-)Vbe should never be
greater than 5 volt for most transistors - even for the high power.
Almost every datasheet tells you so.
What is your opinion about this? What was the PS designers thinking? I
know that the instrument was the state of the art. Please help me to
understand this PS design.
Glenn
(the question is also asked in news://sci.electronics.design )
141T Display.pdf
141T_changes.pdf
to the emitter.
Glenn
