Norm said:
I originally wrote:
and several responders cuationed me that room acoustics would make the
measurement process at best questionable.
But perhaps I simply gave a bad application of a perfectly good instrument
so let me try again. I have several speakers of differing
acoustic-electrical efficiency by which I mean that in a free-field
environment the acoustic energy output per unit of electrical energy input
differs -- the usual measurements come from the factory in the form of dB
SPL re 1 meter per 1 watt input but those details are unimportant. What is
important is that I have several speakers, each with a restricted frequency
range, which I want to use to create an array with flat response, i.e. the
acoustic energy output per unit electrical energy input is approximately
constant across the relevant bandwidth. This is usually done with
cross-over networks which are in reality nothing but electical bandpass
filters. But in terms of matching the acoustic energy from the various
speakers I also need to attenuate the response of some of them relative to
the others. In general, tweeters are much more energy efficient than
woofers, sometimes as much as a decade in power. To do the matching I want
to be able to measure the acoustic energy out of each speaker as a function
of its electrical input. SO ...
How would one go about calibrating a sound-level meter?
Norm
You're still focusing on the wrong problem.
How do you intend to attenuate the drive to the speakers? Unless you
plan to have an amplifier for each one, your attenuator is gonna really
mess things up. That's why purists don't like passive crossovers.
Attenuators are much WORSE.
There are phase shifts. In the crossover, in the attenuator, due to the
relative placement of speakers. You need to measure amplitude and phase
from the listening point to all speakers. The more speakers you cobble
together, the smaller the sweet spot will be...well, I guess there's a
limiting case with an infinite number of speakers in an infinite space
that might work well...
Try this experiment. Put pink noise into your speakers. Use the sound
card spectrum analzyer on the microphone. Experiment with the high
frequency response as you translate/rotate the microphone in space.
Also see what happens if you put a small flat plate behind the
microphone. Just the shape of the microphone and any box that it might
be in can have major effects on the measurement.
Many have gone where you're going. Some have never come back ;-)
Having said all that, it appears that you won't be satisfied until you
calibrate your microphone.
If you're in Portland, Oregon, I have a General Radio Type 1562
Sound-Level Calibrator that we could try out. It put out sound, but
I've never felt the need to use it.
mike
Return address is VALID.
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Compaq Aero floppy,ram,battery.
MINT HP-41CV, 2-METER AMPS, 200CH SCANNER
