LarryD said:
Try checking the high voltage with a CRT voltage checker. If the HV is
there, the tube is probably bad. I've repaired a number of HeNe lasers
through the years. 90% of the dead lasers were dead tubes.
I think the question didn't have to do with a tube that was dead, but one
that was weak.
A tube rated 1 mW is considered end-of-life when its power drops below 1 mW
at the spec'd operating current with proper mirror alignment.
In other words, the power rating is the minimum output power within the
tube's spec'd lifetime.
However, mirror alignment is often an the cause for low power and
that can be corrected.
(But if this was a tube from a Laserdisc player with an output of 0.8 mW.
I would expect that alone not to result in the player failing to operate
correctly.)
--- sam | Sci.Electronics.Repair FAQ Mirror:
http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents:
http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ:
http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites:
http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
