how to write input and output for microcontroller ?
Discussion in 'Electronics Homework Help' started by vead, Sep 15, 2014.
  1. vead
    vead
    473
    14
    Nov 27, 2011
    hello experts
    I want to write input and output for microcontroller in verilog langugae
    I have tried to write code
    Microcontroller has following function
    · ALU
    · Decoder
    · Port
    · Counter
    · Interrupt
    · Accumulator
    · Stack pointer
    · Data pointer
    · Special function register
    · Serial communication
    · Internal rom
    · External rom
    · Internal ram
    · External Ram
    Verilog code
    Code:
    Module mcu (clk, rst, en, p_in, p_out, t_in, t_out, i_in,i_out, rx_in, tx_out ,a0,a1,a2,d0,d1,d2,d3,d4,d5,d6,d7,a,b,s0,s1,s2,f,........etc);
    Rst= reset input
    Clk=  clock input
    En= enable input
    Port
    P_in=port input
    P_out= port output
    Timer
    T_in = timer input
    T_out = timer output
    Interrupt
    i_in= input for interrupt
    i_out,= output for interrupt
    ALU
    A=input
    B=input
    So=input
    S1=input
    S2=input
    F=output
    Decoder
    A0=input
    A1=input
    A2=input
    D0=output
    D1=output
    D2=output
    D3=output
    D4=output
    D5=output
    D6=output
    Can anyone teach me how to write input and output for microcontroller in verilog langugae ?
  2. vead
    vead
    473
    14
    Nov 27, 2011
    look at this example
    what is meaning of ifdef and endif ?
    module oc8051_top (wb_rst_i, wb_clk_i,
    //interface to instruction rom
    wbi_adr_o,
    wbi_dat_i,
    wbi_stb_o,
    wbi_ack_i,
    wbi_cyc_o,
    wbi_err_i,
    //interface to data ram
    wbd_dat_i,
    wbd_dat_o,
    wbd_adr_o,
    wbd_we_o,
    wbd_ack_i,
    wbd_stb_o,
    wbd_cyc_o,
    wbd_err_i,
    // interrupt interface
    int0_i,
    int1_i,
    // port interface
    `ifdef OC8051_PORTS
    `ifdef OC8051_PORT0
    p0_i,
    p0_o,
    `endif
    `ifdef OC8051_PORT1
    p1_i,
    p1_o,
    `endif
    `ifdef OC8051_PORT2
    p2_i,
    p2_o,
    `endif
    `ifdef OC8051_PORT3
    p3_i,
    p3_o,
    `endif
    `endif
    // serial interface
    `ifdef OC8051_UART
    rxd_i, txd_o,
    `endif
    // counter interface
    `ifdef OC8051_TC01
    t0_i, t1_i,
    `endif
    `ifdef OC8051_TC2
    t2_i, t2ex_i,
    `endif
    // BIST
    `ifdef OC8051_BIST
    scanb_rst,
    scanb_clk,
    scanb_si,
    scanb_so,
    scanb_en,
    `endif
    // external access (active low)
    ea_in
    can we write this code in this manner ?
    Code:
      wbi_adr_o,
    wbi_dat_i,
    wbi_stb_o,
    wbi_ack_i,
    wbi_cyc_o,
    wbi_err_i,
      wbd_dat_i,
    wbd_dat_o,
      wbd_adr_o,
    wbd_we_o,
    wbd_ack_i,
      wbd_stb_o,
    wbd_cyc_o,
    wbd_err_i,
      int0_i,
    int1_i,
      p0_i,
      p0_o,
    p1_i,
      p1_o,
    p2_i,
      p2_o,
    p3_i,
      p3_o,
    rxd_i, txd_o,
    t0_i, t1_i,
      t2_i, t2ex_i,
      scanb_rst,
      scanb_clk,
      scanb_si,
      scanb_so,
      scanb_en,
      ea_in
