A
albert
I'm implementing a modulator using a VCO. In order to tune to
different frequencies, a varicap is used. The varicap should be
connected between two pins of the VCO IC, by varing the reverse
voltage between the two diodes of the varicap, different values of
capacitance can be obtained. However, when the pins of the varicap are
connected to a volatage source, at the same time, the corresponding
pins of the VCO IC are also connected through the voltage source.
Consequently, the varicap is bypassed! How to use a varicap on a
breadboard then? Maybe this is a stupid question, but I really have
little practical experience.
Thanks a lot!
Thanks a lot!
