Hi guys,
First post on here so I hope im in the right place.
I am fuel injecting an outboard motor project and need help switching the EMM
I need a voltage trigger between 4 and 12 volts for the EMM
My outboard has a sensor coil that puts out 0.5volts to a powerpack. The powerpack then puts out 200volts to the ignition coils .
Would it be better to use the 0.5 volts or 200 volts to trigger the EMM.
I was think of making a circuit board that gets switched by either one of the voltages and uses that to switch a 12volt supply to switch the EMM.
It will need to be able to switch up to 11000 times per minute..
Any help or guidance is greatly appreciated . I am an outboard technician so my electronics experience is limited.
