how to test optocoupler using multimeter?
Discussion in 'Troubleshooting and Repair' started by Zippora, Sep 14, 2016.
  1. Zippora
    Zippora
    13
    Aug 26, 2016
    how to test transistor side of optocoupler using multimeter?
  2. Minder
    Minder
    3,182
    691
    Apr 24, 2015
    If it is the style where the base has a pin, check with the method usually used on the meter diode range.
    From base to C & E with reversing polarity of the meter.
    M.
  3. Zippora
    Zippora
    13
    Aug 26, 2016
    Thank you for the reply.
    It is 4 pin optocoupler. So only emitter and collector pin is out on transistor side.
  4. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    if it uses a led then you can use the diode setting. again I don't know how to measure the transistor. if it uses a laser then I am not sure how either.
  5. Harald Kapp
    11,989
    2,809
    Use a battery and a series resistor to control the LED side (turn it on/off).
    Use a multimeter in Ω-range to check conduction of the transistor when LED is on, non-conduction when LED is off. That way you check the full photocoupler, not only one part of it.
    If you want/need to qualify the photocoupler in more detail, make the LED curent controllable (controlled current source) and wire the transistor side with load resistor and voltage source. Measure collector current as a function of LED current and compute the current transfer ration Ic/Iled.
    Get a datasheet for the photocoupler, these typically show recommended test setups for the component.
    Tha fios agaibh and HellasTechn like this.
  6. Zippora
    Zippora
    13
    Aug 26, 2016
    Thank you.
