how to test a quadrac out of circuit?
Discussion in 'Electronic Basics' started by Bill Sanderlin, Jan 4, 2009.
  1. I have a 6015LT-ND quadrac that I would like to test out of circuit. Is
    this possible and how would I do it with a simple DVM?
    Bill
  2. Jamie
    Jamie Guest
    You would need the spec's on the unit.
    in short, you have M1, M2 and T legs.
    I don't know what your devices pin configuration is
    how ever, I'll guess it to be M1,M2 and T as in 1,2,4
    reading left to right while looking at the front side
    of the package.
    M1,M2 should not read anything on your DVM in diode
    mode either way. It should be in the infinite reading of
    your meter.
    T (trigger) should also not read anything related to any
    of the M1,M2 legs. That leg requires a minimum level of
    voltage before the internal diac breaks over to bias the
    TRIAC.
    If you're getting any form of low reading with any combination
    of this device, I consider it to be defective.
    It might be best to actually test this in circuit using a
    Volt meter..
    The T leg should have around 30..50 volts AC before it can
    trigger. The M1/M2 should have AC constantly there at all times.
    The remaining M1/M2 will be on the load side..
    http://webpages.charter.net/jamie_5"
  3. ----------------------snip-----------------------------
    Thank you! Exactly the information I was looking for as the problem I had
    has been solved.
    Bill
