How to tell if a microcontroller is reprogrammable or not?
Discussion in 'Microcontrollers, Programming and IoT' started by Rtg, Jun 1, 2016.
  1. Rtg
    Rtg
    3
    Jun 1, 2016
    I am a newbie in the microcontroller field and have started a project designing a gas sensor using PIC16F917. Is it reprogrammable? And can it be simulated using Proteus? Can the code be burnt using MPLAB? It is surprisingly difficult to ascertain. I think the Proteus part is true.
  2. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    Read the μC datasheet,you will find the answer there.
    Do the same for the programmer and simulator.
  3. Rtg
    Rtg
    3
    Jun 1, 2016
  4. Colin Mitchell
    Colin Mitchell
    1,417
    312
    Aug 31, 2014
    This is what you look for:
    High-Endurance Flash/EEPROM cell:
    - 100,000 write Flash endurance
    - 1,000,000 write EEPROM endurance
    - Flash/Data EEPROM retention: > 40 years
    You can reprogram it 100,000 times.
    You can load the EEPROM 1,000,000 times.
    hevans1944, Rtg and chopnhack like this.
  5. dorke
    dorke
    2,342
    665
    Jun 20, 2015
    I couldn't find anything ,did you?
    Can you read English?
    First page says "Flash based",google it and translate it to Hindi if you have to !
