How to take time average of high side current sense amplifier output?
Discussion in 'Electronic Design' started by M. Noone, Dec 20, 2005.
  1. M. Noone
    M. Noone Guest
    High - I'm planning on using a MAX4372H
    (http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2104) high side current
    amplifier to monitor current use in a small motor. I plan on using a
    ..025 ohm 0805 1% resistor (digi-key WSLA-.025CT-ND, see here:
    http://dkc3.digikey.com/PDF/T053/1168.pdf) for current sensing. I will
    also have a .1uf ceramic decoupling cap from vcc to gnd. The output
    from the MAX4372H will be attached to a 10b ADC.
    My primary question is this: I plan on sampling from this ADC at
    probabaly about 1khz. When I take each sample I'd like the sample to be
    the average current since the last sample was taken - so I'd like it to
    be the average current over the last 1/(1khz) or the last 1ms.
    Implementation of this is where I get a bit confused. Would this be an
    application for a low pass filter? Or something else? Can anybody
    suggest a circuit that would work for this?
    Secondary question: is there anything wrong with my plan? At that small
    of a resistance - do I need to worry about things like the resistance
    of the traces, the solder, or the pads? I plan on having the current
    sensing resistor directly between the two current sensing pins (RS- and
    RS+) - so trace length between the pins and the resistor will be maybe
    ~1-2mm or so.
    Thanks for your help,
    -M. Noone
  2. Dan Hollands
    Dan Hollands Guest
    An R in the line from maxim to ADC with a cap to ground at the input of the
    ADC would "average" out the signal i.e. remove high freq components so that
    that you don't get false readings if the sample falls on a current spike.
    Only other concern is whether the .025 ohm gives the correct volts needed at
    the expected current and to make sure resistor can handle the power. You
    will need some way to calibrate the circuit - either with a pot or in the
    processing of the digital output. That should take care of the actual
    resistor value and anyother minor resistances.
    Dan
    Dan Hollands
    1120 S Creek Dr
    Webster NY 14580
    585-872-2606
    www.QuickScoreRace.com
  3. M. Noone
    M. Noone Guest
    Hi Dan - can you reccomend how to calculate values for the resistor and
    capacitor?
    About the choice of 0.025 ohms - max current should be under 500ma, but
    I want to be able to sense past that. Vref on the ADC is 2.048V. so to
    calculate max current: Imax * 0.025 * 100 = 2.048, which gives Imax =
    819ma. The current sense resistor is rated for an 0.125W. So
    0.819^2*.025 = 0.0168W, so I have plenty of room there.
    -M. Noone
  4. Mark
    Mark Guest
    regarding your question about the low resistance and the traces....
    look up "Kelvin connection"
    you need to understand and use this type of connection for this
    application....
    this type of connection will eliminate the problem of the trace
    resistance
    Mark
