how to show routing slot and v-cut line.
Discussion in 'General Electronics Discussion' started by eva liang, Jan 12, 2016.
  1. eva liang
    eva liang
    6
    Dec 31, 2015
    can i know that how many way could show the routing slot and v-cut line at the gerber design? Is there some way to show the rounting slot and v-cut line directly and easly at the gerber file?
    thanks in advance.
    eva
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Add instructions as a mechanical layer in the PCB design. Then output this as Gerber data when you do the other layers. Alternatively some of the higher end Gerber software packages allow you to do this properly with graphical elements. I guess you don't have a high end Gerber software package.
    Adam
  3. eva liang
    eva liang
    6
    Dec 31, 2015
    yes, this is the problem you say and now i have slove the problem how to show the v-cut line and routing slot. Everything is going well.
    thanks so much your help.:)
    regards,
    eva
