B
Bernhard Kraemer
Hello,
For an experiment, I need to build a little Lock-In Amplifier an my own
circuit. I do not have an external Lock-In and so this will be the cheaper
and better solution.
The circuit is nearly finished. What lacks is a circuit which should be
controlled by an external oscillator and produces a two output signals,
a TTL signal of the same frequency and another of 90 degrees
phase shifted. The frequency range should be about 10 Hz to 10 KHz (7
decades).
I thought about first producing a sine and a cosine signal which I am
going to convert to TTL afterwards.
In "The Art of Electronics" p 294, if found an interestin circuit using
the AD639. Unfortunately, our official provider Farnell doesn't offer the
IC saying it wouldn't be produced nomore.
There is another circuit on the next page using a lot of resitors and
capacities, but it only works for 2 decades instead of seven and
honestly, I would not even know how to calculate the necessary values
Finally, having tried another couple of ideas, I still don't figure out
how I can solve my problem. This is why I post on this forum. How could
I compose a circuit dephasing either two sinusoidal or digital signals
by 90 degrees (and if possible, without too much costful and placetaking
electronic circuitry)?
I hope someone could help me.
Yours,
Bernhard
decades).
Yours,
Bernhard
