how to set up cctv network?
Discussion in 'Security Alarms' started by supercool, Aug 31, 2005.
  1. supercool
    supercool Guest
    does anyone know of a web site that show you how to set up a CCTV
    network of cameras, how to strip the rg59 cable and crimp it, how to
    set up PTZ cameras, and how to intergrate then into a DVR. i know its
    going to be different for each dvr, but any help would be nice.
  2. Bob Worthy
    Bob Worthy Guest
    And you haven't learned how to strip RG59 yet? Don't put the cart before the
    horse. There is alot to learn just with installing the cable, power and
    telemetry wiring ie: installation codes, proper wire and size for the
    application, conduit fill specs., installation methods etc. Then you will
    get into the cameras, lenses, PTZ's, domes, housings, mounts, power
    supplies, UPS's, routers, and DVR's. You probably will have a hard time
    finding a website that will teach you what you need to know. It takes hands
    on training to learn alot of what is necessary. DIYers struggle through
    their own home installations and is usually more of a hobby. The equipment
    you are outlining sounds more of a commercial type application and probably
    should be looked at by someone already versed in CCTV applications. Don't be
    misled because you can find this equipment on the internet and think it is
    no big shake because you have hooked up a VCR before.(no flame intended) To
    have a system installed and set up properly does take some experience.
  3. Crash Gordon
    Crash Gordon Guest
    or you can do what most people do:
    Buy the cheapest stuff they can find.
    Open the boxes and lose the instruction manuals and receipt.
  4. James
    James Guest
    RG59 ?, You will get a much better picture with RG6
    James
  5. Crash Gordon
    Crash Gordon Guest
    This was 21 years ago.
  6. James
    James Guest
    oh, my bad
    James
  7. Guest
    Only diff with RG6 is you can run it longer, but it has to be copper
    center and copper braided, otherwise simple cable TV RG6 which
    generally has aluminum braid, will be a much worse picture and not go
    any distance at all.
  8. Crash Gordon
    Crash Gordon Guest
    They didn't have 6 back then only 59 & 56
  9. Guest
    my bad, before my time :)
  10. Crash Gordon
    Crash Gordon Guest
    whippersnapper.
  11. Jim
    Jim Guest
    RG59's a lot better than drums and smoke signals.
