How to set counter's in queue
Discussion in 'Microcontrollers, Programming and IoT' started by Daljeet12, Apr 28, 2019.
  1. Daljeet12
    Daljeet12
    21
    Jun 16, 2018
    I have pic16f877a microcontroller and I am writing my code on MPLABX XC8. The sensor is connected to RB1, an encoder is connected to RC0 and LED is connected to RD4
    I have written a program for counter that can count 10 events
    Code:
    // CONFIG
    #pragma config FOSC = HS        // Oscillator Selection bits (HS oscillator)
    #pragma config WDTE = OFF        // Watchdog Timer Enable bit (WDT disable)
    #pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
    #pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
    #pragma config LVP = OFF        // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
    #pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
    #pragma config WRT = OFF        // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
    #pragma config CP = OFF         // Flash Program Memory Code Protection bit (Code protection off)
    #define _XTAL_FREQ 20000000 //Specify the XTAL crystal FREQ
    #include<xc.h>
    void main(void)
        PORTD = 0b00000000;
        TRISC0 = 1;    //PORTC R0  pins are used as Input encoder
        TRISD4 = 0;    //PORTD R4  pins are used as output.LED
        TRISB1 = 1;    //PORTB R1  pins are used as Input. sensor
         //Loading starting value of counter 65486
        TMR1H = 0xFF ;    // High byte FF
        TMR1L = 0xF6 ;    // Low Byte F6
        //Set T1CON Register
        TMR1ON  = 0; // Stops Timer1
        TMR1CS =  1; // Oscillator is enabled
        T1SYNC =  0; // Synchronize external clock input
        T1OSCEN = 0; // Oscillator is shut-off
        T1CKPS0 = 0; // 1:8 prescale value
        T1CKPS1 = 0;
        TMR1IF = 0 ;  // Clear interrupt flag
        TMR1ON = 1; //Start Timer1
        while(1)
           if(TMR1IF ==1)
              RD4 = 1;  // LED ON
              __delay_ms(500); //
              RD4 = 0;  // LED OFF
              TMR1IF=0; // Clear timer interrupt flag
              TMR1ON = 0; //Stop Timer1
              //reload counter
    I want to set multiple counters ( 5) in the queue whenever the sensor triggers set the counter in FIFO
    When the sensor triggers the first-time set counter 1 and when timer overflow flash led
    When the sensor triggers the second-time set counter 2 and when it timer overflow flash led
    When the sensor triggers the third-time set counter 3 and when it timer overflow flash led
    When the sensor triggers the forth-time set counter 4 and when it timer overflow flash led
    When the sensor triggers the fifth-time set counter 5 and when it timer overflow flash led
    How to accomplish in programming? any suggestion would be appreciated
  2. Harald Kapp
    9,394
    1,918
    You use a variable to count how many times the sensor has triggered. Set this variable to 0 at the start of the program. Whenever a trigger occurs you check the value of this variable (e.g. in a switch statement) and perform the required action. Then increment the variable to be ready for the next trigger.
    Daljeet12 likes this.
  3. Daljeet12
    Daljeet12
    21
    Jun 16, 2018
    Done
    Code:
    // PIC16F877A Configuration Bit Settings
    // CONFIG
    #include<xc.h>
    void main(void)
        PORTD = 0b00000000;
        int Trigger = 0;
        TRISB1 = 1;    //PORTC R0  pins are used as Input. sensor
        T1CKPS1 = 0;
        while(1)
         if (RB1 == 0)
          else if(TMR1IF ==1)
              RD4 = 1;  // LED ON
              __delay_ms(500); //
              RD4 = 0;  // LED OFF
              //reload counter
    example code for switch case
    Code:
    switch (Trigger) {
        case 1 : "counter1"
           break;
        case 2 : "counter 2"
           break;
        case 3 : "counter 3"
           break;
        case 4 : "counter 4"
           break;
        case 5 : "counter 5"
           break;
    I have mentioned counter 1 counter 2 up to counter 5 for example
    How to perform the required option in place of a counter name?
  4. Harald Kapp
    9,394
    1,918
    Look up the switch statement in any of the many c-manuals online.
  5. Daljeet12
    Daljeet12
    21
    Jun 16, 2018
    My code is not working as expected When sensor triggers LED doesn't flash
    Do you see something wrong in the code ?
    Code:
    // CONFIG
    #include<xc.h>
    void main(void)
        PORTD = 0b00000000;
        int Trigger = 0;
        T1CKPS1 = 0;
        while(1)
         if (RB1 == 0)
          else if(TMR1IF ==1)
              RD4 = 1;  // LED ON
              __delay_ms(500); //
              RD4 = 0;  // LED OFF
              //reload counter
