How to select Vref?
Discussion in 'Microcontrollers, Programming and IoT' started by sid2286, Sep 24, 2012.
  1. sid2286
    sid2286
    102
    Aug 24, 2011
    I'm using PIC18F4520 for my project. my input for ADC is 200mV to 1.2V.
    now i want to give vref to my microcontroller. It has to pin RA3/AN3/
    VREF+ and RA2/AN2/VREF-/CVREF pins.
    So how do i give Vref? should i apply 1.5v to only VREF+ and keep open VREF- or should i ground the Vref- pin??
    Please help.
    Rgds,
    Sid
  2. GreenGiant
    GreenGiant
    842
    7
    Feb 9, 2012
    it should be you only have to connect the 1.5 to the +Vref but connecting ground to the -Vref should not have any negative affects, this is drawing from experience with Arduino's NOT PIC's so I'm not 100% sure if they work the same
  3. BobK
    7,682
    1,689
    In PICs you can separately specify whether Vref+ and Vref- are internal or external. You would leave the Vref- internal, which connects it to ground and frees that pin for other uses. Also check the datasheet for the minimum Vref. I think 1.5V is going to be too low.
