How to rust proof underwater alligator clips?...tia sal
Discussion in 'Electronic Repair' started by Guest, Jul 20, 2005.
  1. Guest
    Guest Guest
    Greetings, All
    I 'm doing some under water test but my alligator clips are rusting due to the fact that they are not
    coated with rust proof materials. Does anyone know which material to use to rust proof alligator clips
    (I purchased them from radio shack) The alligator clips are used to transmit voltage underwater but they rust after a day.
    If I paint them with a rust proof material, the material will still have to be able to conduct electricity
    any ideas what i can use?
  2. Cees Keyer
    Cees Keyer Guest
    try coating them with copper, in an copper sulfide solution or something...
    I am not a chemist so i don;t know the details.
  3. GregS
    GregS Guest
    With all those clips, you first MUST solder them. The crimps will fail
    very soon. They are bad enough out of water. Very loosly made.
    Salt water? Good luck.
    I would just cover them in silicone grease.
    greg
  4. use to rust proof alligator clips
    Jilss-
    Try coating them with grease. The contacts are under some pressure from
    the clip's springs, so the grease will be squeezed away from the contact
    point.
    Fred
  5. sofie
    sofie Guest
    jilss:
    Do you Google? If you have never used a search engine you should try it.
    Lots of information on the Internet at your disposal on your home computer.
    In just about 30 seconds using the search words "stainless steel alligator
    clips" on Google web search I found the following website and source:
    http://www.lakewoodproductsinc.com/alligator.htm
    If the above is not satisfactory, look at the other hits as a result of the
    Google search..... there should be a few other good ones out of the 39,300
    total hits that came up.
    Best Regards,
    Daniel Sofie
    Electronics Supply & Repair
  6. Ken Weitzel
    Ken Weitzel Guest
    Hi jilss
    If the budget for your test can stand it you should be
    able to find some at a medical supply house.
    Think you'll find stainless steel, silver plated, and
    even gold plated :)
    Take care.
    Ken
  7. JANA
    JANA Guest
    There people may have what you want. http://www.marinco.com/
    I cannot remember directly who supplies what you want. What you need are
    corrosion resistant alligator clips. Usually these are made from stainless
    steel, or any metal that is non corrosive.
    JANA
    _____
    Greetings, All
