How to revive a LITHIUM Ion BATTERY
M
Max
Hi , having a 12-Cell Lithium Ion Battery that goes on a NEC laptop.
The battery doesn't keep the charge for a long time. Are they repairable ?
S
Sam Goldwasser
Only if your fire and medical insurance is paid up and you know where the
nearest fire station and emergency room are. :)
In short, no.
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
Jerry G.
These should be replaced. This revival thing about batteries is not reliable
and safe.
Jerry G.
K
Kevin R
Travis Jordan said:
The article fails to mention that many batteries have charging /
metering electronics in them, and that sometimes these fail instead of
the batteries. Repair and replacement of the electronics is a bit
more.....trouble.
true but most are battery issues
Kevin
M
mike
Kevin
That's not been my experience. When you remove power from the
electronics, the battery monitor chip can't be reset without
knowing what to do or having the right software. I've managed a couple
that used chips that have data sheets. Most have been dismal failures.
Good cells that still won't run the computer.
If the pack is still alive, some have reported success by wiring up a
bunch of power supplies and replacing the cells "hot".
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
