How to remove D-Protection on LG Home theater
Status
Not open for further replies.
Enoch
Oct 1, 2018
Oct 1, 2018
I have being using my LG Home theater for close to a year now. But unfortunately this night my wife was looking movies, she switched it off and later when we tried to put it on again, its come on and few Seconds later it show D-PROTECTION.
Please help me to remove the D-PROTECTION on my DVD LG Home Theater LHD655
NO SIGN OF BURNING
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
D-Prot appears to be a generic error message that does not indicate a single cause. I'd unplug it from the wall outlet then turn on to see if it goes away, otherwise opening the unit and looking for faults, or is that what you did when you wrote "no sign of burning"? Did you also look for failed capacitors, domed on top or leaking?
Since this is a DVD and amp all in one, I would look closer at the amp portion first, though for the power rating and size it is probably a class D amp which can be a little more work to reverse engineer and trace the circuit. That might begin with determining the amp chip and getting the datasheet, then measuring signal to its input pins, signal out of its output, and power input.
If there is an active protection circuit as there seems to be, it may have shut down the output so you could look for shorts including output transistors if the amp chip does not have that last stage of transistors built in.
Harald Kapp
13,738
13,738
Sunnysky
Jul 15, 2016
541
Jul 15, 2016
541
Factory reset= hold down zero key on remote and Then Stop button on unit for 5 sec without a disc inside
Marcus111
Oct 3, 2021
Oct 3, 2021
I have tried factory reset but still the d protection is still there
How can I get rid of it somebody please help
davenn
14,263
14,263
replace the main board as suggested earlier in the thread
Status
