A
Andrew Xiang
for my inverting amplifier, the gain is 100v/v 40dB. the noise floor
is about 100uV=0.1mv, after 40dB, it is about 10mv and noticable on
the speaker, worse yet, there is 120hz, 240, 480hz harmonics present,
very noticable, The white noise level is actually acceptable, I would
still appreciate it if someone can help me reduce the 100uV noise. But
I really want to remove the 120hz harmonics.
I used 3 stage linear regulator. 15v->5v->3.3V. the last one is a low
noise LDO, noise is about 30-40uVRMS, I guess 100uV is reasonablely a
good design for the ground plane? The opamp is TL074 jfet input
low-noise opamp.
Anyway, the 120hz harmonics is the key, how can I remove thme?
thanks
Andrew
low-noise opamp.
thanks
Andrew
