M
Mary Fisher
Paul M. Eldridge said:Through a number of lighting upgrades (e.g., replacing halogen display
lighting with ceramic metal halide track heads)
Can you tell me more about these, please?
Mary
Those figures are impressive, I think, but what's a COP?
A Coefficient Of Performance is a ratio of heat power moved to electrical
power used to move it, in the same units. For instance, if a heat pump
uses
1368 watts of electrical power to move 14K Btu/h (14K/3.41 = 4100 watts)
of heat, the COP is 4100/1368 = 3. If an oil-fired forced-air furnace
moves
50K Btu/h of heat using 500 watts for the blower and pump, we might say
the COP is 50K/3.41/500 = 29. If we move 54 kWh of warm air from sunspace
into a living space with the help of a 2 watt damper motor running 3
minutes per day, the COP is 54kWh/0.1Wh = 540,000.
But heat pumps are expensive, with a very low COP, compared to some solar
systems, and a house can store overnight heat from sunspace warm air in
its thermal mass. Big Fins (TM) or fin-tube pipe near the top of an air
heater inside a sunspace can collect and store higher temp heat in a tank
for a few cloudy days and hot water for showers, with help from
a greywater heat exchanger.
We might store overnight heat in thermal mass under a foil-covered ceiling,
eg a flat helix with 10'x4" PVC pipes full of water, with no water movement
on average days and tank water flowing through the pipes on cloudy days,
with a slow ceiling fan and a room temp thermostat to bring down warm air
as needed.
Nick
You might do lots of things. But until you can prove anything actually
works with many installations and hard data, then it is still in the =
might stage.
