How to protect battery from a power adapter?
Discussion in 'Power Electronics' started by Switchy Cat, Jul 26, 2020.
  1. Switchy Cat
    Switchy Cat
    6
    Jun 5, 2020
    I want to start building projects which will have the option to use a 9v battery and 9v power adapter.
    I imagine a diode can protect the battery from the power supply.
    Is that sufficient if both the battery and power adapter were connected by accident?
  2. Bluejets
    Bluejets
    4,092
    857
    Oct 5, 2014
    Would make more sense to ensure this cannot happen in the first place.
    Years gone by, manufacturers would make the power supply inlet a self switchable unit (plug operates switch in the socket)
    Switchy Cat likes this.
  3. Switchy Cat
    Switchy Cat
    6
    Jun 5, 2020
    I believe you are correct. I will investigate this further, but it seems true that the plug has a mechanism that switches a contact off for the battery.
  4. Switchy Cat
    Switchy Cat
    6
    Jun 5, 2020
    @Bluejets
    This is confirmed. The jack has a built in mechanism. Thanks!
  5. kpatz
    kpatz
    271
    62
    Feb 24, 2014
    A switched DC jack is ideal as mentioned. If you use diodes, you'd need one on the DC power input as well as on the battery. One to prevent the battery feeding into the DC jack (if the adapter is connected but unplugged), and another to prevent the DC input from feeding into the battery. You'd also need to make sure the DC adapter voltage is higher than the battery's, otherwise you'll still be drawing from the battery when the DC adapter is connected (higher voltage "wins").
