A
Adrian
I am trying to construct a digital pressure gauge by using a pressure sender
(10-180ohms over 0-150psi) and a volt/ohmmeter.
I already have a commercial unit and have taken psi-to-ohms measurements.
Performing a regression on the data I achieve an approximately linear
function with the equation:
PSI = 0.8289 x ohms - 13.0786
In other words, if the pressure sender reads 100 ohms, the actual pressure
is 0.8289(100)-13.0786 = 70psi which is the value I would like to display on
a volt/ohm meter.
How would I implement this function with a resistor network? I think the
most difficult part is to get the negative value.
a volt/ohm meter.
