I'm a chemist not an engineer and imagine this must a really basic problem but I'm a complete newbie.
I'm trying to light a UVC LED, with 6.5V forward voltage and 200mA forward current.
I connected to a 30 V benchtop power supply set to 6.5V but nothing happens.
As i missing something fundamental here? All help appreciated.
https://docs.rs-online.com/86f6/A700000006912426.pdf
Agree with everyone that you probably burned out your led as soon as you plugged it in. Also that you need a good heat sink. 1.3 watts will need about 1.3 square inches of metal to radiate the heat produced. Hopefully the LED is mounted on a "star" base already? If so just attach the star base to some aluminum with thermal epoxy or paste (aluminum channel works well) and you're good to go. You might try this device:
https://www.ledsupply.com/led-drivers/boostpuck-dc-boost-led-driver
It will boost your 5V from the USB power supply so that the voltage is appropriate for your LED. Off the shelf, can control it with just a few resistors.
Be careful, though, the voltage difference between the input (5V) and output (6.5 or there-abouts) might be too small for the boost system. These systems are very touchy. Would work better with a higher voltage output.
Also not the rated current is 350 mA, you'll have adjust the current output DOWN to have it work properly. Just takes a resistor across two prongs on the boost puck.
I would wire TWO of your UVC emitters in SERIES (for a total voltage of 13V). Then run 200 mA through them with a boost puck. Should work beautifully, and all you have to do is connect stuff together with a few resistors. Will pull about 611mA from your usb power supply.
Andrew
