I have a LG Flatron M2550D-PZ TV. It is not obvious how to open the case, to get acces to the speakers. Please help !!
The TV is from Oct.2009. There is only one little screw in about the middle of the back.
Welcome to the world of hidden plastic clips!
If this is the case.. guessing and opening it yourself can damage many/all of the clips which means you won't be able to close it back up properly.
When in doubt, find a book. (Unless it's a junker, then go crazy!)
The speakers are on the bottom, remove the cover and you will have access to the speakers, I'm assuming you have a lcd or plasma tv. They are connected to the main so if you need to replace them just unplug from the main.
