How to monitor an actuator's feedback line from a microcontroller?
Discussion in 'Microcontrollers, Programming and IoT' started by markdire, Aug 31, 2018.
  1. markdire
    markdire
    4
    Aug 31, 2018
    [​IMG]
    the AG-020-B electric actuator is controlled from a microcontroller. Terminal 1 is connected to the DC PSU GND, Terminal 2 is connected to the +24VDC via a high side Power MOSFET(TPS22810) as shown below. This is for power saving.
    [​IMG]
    Low side MOSFET (AUIPS1021) Q5A and Q5B are used to control the opening/closing of the valve via terminal 3 and 4. The microcontroller I/O lines Valve_Ctrl_1a and Valve_Ctrl_1b provide a 3.3V signal.
    [​IMG]
    - Comments are welcome regarding the power and switching circuitry.
    - Any suggestion on how to monitor the feedback lines on terminal 8 and 10 from a microcontroller. A lamp is not suitable as the system will be enclosed in a box. I've come up with a relay as a possible solution but I would rather use discrete devices.
    [​IMG]
  2. WHONOES
    WHONOES
    886
    218
    May 20, 2017
    How about a resistor to pin 8 with a 3.3V zener at the ground end with the junction of the two connected to your μP.
    Then a 1 would represent "open" and a 0 "closed". Same on pin 10. This assumes that the supply is dc not ac.
  3. markdire
    markdire
    4
    Aug 31, 2018
    Would you mind drawing a diagram?
  4. Bluejets
    Bluejets
    4,056
    847
    Oct 5, 2014
    Opto isolators.
    Open collector output.
  5. Alec_t
    Alec_t
    2,822
    754
    Jul 7, 2015
    How about
    This assumes pins 7-10 are not connected to any other supply.
  6. markdire
    markdire
    4
    Aug 31, 2018
    How would you connect an Opto isolator to terminal 8 and the GPI?
  7. Bluejets
    Bluejets
    4,056
    847
    Oct 5, 2014
    Maybe like this....
    markdire likes this.
  8. WHONOES
    WHONOES
    886
    218
    May 20, 2017
    Got around to doing your sketch. See attachment.
    Couldn't be simpler.
    Circuit is same for both.
  9. markdire
    markdire
    4
    Aug 31, 2018
    There is no actual lamp in the real thing, it's just an example from the datasheet. And you have only access to one side of terminal 8 (customer wiring)
  10. WHONOES
    WHONOES
    886
    218
    May 20, 2017
    So, what voltages are there on pins 8 and 10?
