How to modulate Manchester Code
Discussion in 'General Electronics Discussion' started by suki, Jul 18, 2010.
  1. suki
    suki
    11
    Jul 11, 2010
    I have develop a circuit which taking a series of binary number and change it into Manchester code. then, I need to modulate the Manchester code, is it possible to modulate it into FSK because I found that Manchester code only can be modulated into PSK. help me to figure this out pls.
  2. (*steve*)
    25,480
    2,826
    It's a signal. You can modulate a carrier using FSK, PSK, AM, FM, or QAM if you feel like it.
    However, manchester encoding is a scheme in which data and clock are encoded together using what is essentially a phase shift modulation. If you view the output as a signal, then it can be used to modulate another signal.
    I'm not sure that you gain anything by doing this though. One has to ask "why not modulate using the original data stream?"
  3. suki
    suki
    11
    Jul 11, 2010
    thanks for the reply.
    act i am investigating the circuit for NFC system, since i am not connecting with the computer for the source input, i try to feed with the manchester code instead. i am expecting to obtain the modulation for the input ive given. however, when i used the vco to modulate it, it is not giving me the correct answer. its giving me the uncertain pulses.
    ive attached the circuit and simulation result. can u hv a look and give me opinion with the results?
  4. (*steve*)
    25,480
    2,826
    My worry is that if your clock and data are not changing state at *exactly* the correct time that you will get very short pulses at each data transition.
    I would be looking for a method that removed that possibility..
  5. suki
    suki
    11
    Jul 11, 2010
    how about the circuit do u think? is it a make-sense circuit for u?
  6. (*steve*)
    25,480
    2,826
    I don't really understand why you use a voltage divider than an op-amp with gain. I also don't see exactly where those traces are coming from.
    I suspect one of the traces shows runt pulses caused by propagation delay, but I can't be sure.
  7. suki
    suki
    11
    Jul 11, 2010
    can you give me any idea in how should i build the encoder and modulation part for this circuit pls? any simple idea. maybe i dont have to use the op-amp part and just directly feed into the vco. what do u think?
  8. (*steve*)
    25,480
    2,826
    What voltage swing does the VCO require? Do the logic and op-amp share a common 0V rail?
  9. suki
    suki
    11
    Jul 11, 2010
    the vco needs 5v. no, only the om-amp uses the 0v.
  10. (*steve*)
    25,480
    2,826
    If only the op-amp uses 0V, then what is the (presumably) 5V for the logic referenced to?
