How to mod this ciruit
Discussion in 'General Electronics Discussion' started by Key, May 11, 2014.
  1. Key
    Key
    May 11, 2014
    I got this switchpod at a boneyard to use the unwired for fog light switch for a replacment of the non stock switch I've been using to manually run the radiator fan. One wire from the relay carrying 12v switching to ground, triggers the relay and runs the fan. I can get it to work by replacing the yellow wire with the wire coming from the fan relay, but only if I have the parking and or head lights on as well. Thats where my eyes glaze over trying to figure what needs to be changed. I have no problem going at this with a soldering iron once i know which bits need what changes.
    PDF of the diagram is here, If ya need to see another curcuit , I have more I could upload.
    http://pdfcast.org/pdf/headlamp-and-fog
  2. Key
    Key
    May 11, 2014
