how to measure current from the capasitor
Discussion in 'Electrical Engineering' started by Joja, Dec 15, 2006.
  1. Joja
    Joja Guest
    How can i measure current ( with multimetar ) of 35V capasitor with 100uF
    capasity ?
    Should i connect resitor and how ?
  2. Joja
    Joja Guest
    Terry, you have helped me very much! Thank you ! Sorry for long replay time.
    This is the redefined question, an the problem:
    Im making some small test project where i want to control the discharge of
    fully charged capasitor ( this is the end part ).
    For start i need to understand this situation:
    Let's take stronger capasitor : 6000 uF at 18V
    - Capasitor will be charged thru 2x9V battery.
    - battery is common eu 9V battery (varta) and it is non rechargeable.
    1.) When i connect capasitor to battery and when capasitor is full he should
    have 18V
    Question:
    1.) How much current is on this capasitor ?
    2.) If i would use some different DC input ( 18V ~ 2mA ) to charge
    capasitor, how much current will be then, on this capasitor ?
    Basicly, i want to find out how to calculate current on the capasitor when
    you have constant defined voltage input (with low or very low current).
    Thank you in advance !
  3. Joja
    Joja Guest
    First you need to understand better how to use the word 'current'.
    I agree. I have used this term from the last post.
    But you know what im asking and why :)
  4. Joja
    Joja Guest
    Hi !
    Thank you (and Terry ) for your time and help.
    Joja
    p.s. sorry for my typing errors.
  5. Joja
    Joja Guest
    Happy Christmas to you too and to all your family and friends !
