R
Rock Braud
I am chasing down a problem with my Emerson 27" model MS2700RDA.
The picture has about 20 "retrace" lines across it, the image is
barely visible, and red dominates the color.
I have done some research and am trying to determine if there is a CRT
short and if so where it is.
When measuring voltages on the CRT pins should I have my DMM set on DC
or AC.
Also, I am placing the negative lead on the CRT Header Element ground
pin; is this correct?????
When I measure the cathodes, Red, Green, and Blue, wrt heater filament
ground, I get the proper voltages; 155-165 VDCon all three and they
are usually within 1 volt of each other.
However, when I measure VDC "across" the heater filament I get 0 VDC.
But, when I measure it for AC voltage, I get around 2 or 3 VAC. What
is the correct way to measure heater filament voltage???
Finally, when I measure Pin 5, a.k.a. screen grid, I get 0 volts, both
AC and DC settings. Shouldn't I be getting 21-26 Volts? How should I
measure screen grid voltage?
I have measured resistence across all combinations of pins. All
combinations show infinite resistence EXCEPT across the header
filament AND Pin 4 ("blanK") and the filament which is 150 ohms if I
recall correctly. Or is it 150 kohms? Anyway what resistence should I
get across the heater filament and what is Pin 4???
Thanks.
or AC.
Thanks.
