How to measure amperage on a solar panel
Discussion in 'General Electronics Discussion' started by mrel, Sep 15, 2021.
  1. mrel
    mrel
    109
    Jul 2, 2008
    Hello
    Two 100 watts solar panels connected parallel ,how to measure amperage out of two panels.
    Do i need to put a Load on the solar panel?
    mrel
  2. Externet
    Externet
    776
    168
    Aug 24, 2009
    If you do know they are 100W each in parallel, you need a 200 W load and DC ampermeter in series to measure maximum capability.
    If the load is not 200W, you still need an ampermeter in series to your load of choice.
  3. Bluejets
    Bluejets
    5,001
    1,050
    Oct 5, 2014
    The back panel should have the details.
    Other than that do a short circuit test.
    100w panel should show a couple of amps in bright sunlight on a current range on a multimeter.
  4. mrel
    mrel
    109
    Jul 2, 2008
    Can i just hook amperage meter in series positive wire of solar panel to meter to negative wire of solar panel to the meter and get amperage reading will that work?
  5. mrel
    mrel
    109
    Jul 2, 2008
    mrel
  6. Externet
    Externet
    776
    168
    Aug 24, 2009
  7. Bluejets
    Bluejets
    5,001
    1,050
    Oct 5, 2014
    Seemed it might have been what was required.
