wrongsideof40
- Dec 29, 2017
- 4
- Joined
- Dec 29, 2017
- Messages
- 4
Hi folks - I have a touch-sensitive switch, intended for use with Arduino, like this...
https://www.ebay.co.uk/itm/TTP223B-...742124&hash=item2a5c1681ab:g:faQAAOSwLzdWSXos
It has a three-pin connector: VCC, OUT and GND. Touching the switch momentarily switches the output from low to high. What I actually want to achieve is the effect of having an on/off switch which is normally open circuit, then closed circuit (or 0V), when closed. The power drawn by the load will be negligable (1mA approx) so no need for relay, etc.
Can anyone please suggest the simplest, solid-state way of achieving this. I'd like to continue to use the PCB, as the touch interface is just right for my needs.
Any help very much appreciated.
