How to make a circuit to test ringers in rotary telephones ?
Discussion in 'General Electronics Discussion' started by Electric Al, May 24, 2015.
  1. Electric Al
    Electric Al
    85
    7
    Jan 16, 2014
    From 120 volt a/c or from a battery source .... how to make a ringer tester for rotary telephones , without a connection to a telephone line ?
    I have a ringer which requires 12 volt d/c primary and the secondary Vout is supposed to be 70 v r m s .
    I can not get any secondary output voltage at all , and I assume the circuit is open !
    It is intended to produce 70 V r m s (V out) and 3 W r m s (P out) at 20 Hz.
    Is there any other way to achieve the correct voltage I need to temporarily ring a rotary telephone ?
    Any help will be appreciated !
  2. Martaine2005
    Martaine2005
    3,514
    953
    May 12, 2015
    Is this the OLD rotary phone with the two large caps and relay/solenoid?
  3. Electric Al
    Electric Al
    85
    7
    Jan 16, 2014
    Standard rotary Telephone eg: Northern Electric or Western Electric 500 series .
  4. Martaine2005
    Martaine2005
    3,514
    953
    May 12, 2015
  5. Externet
    Externet
    762
    166
    Aug 24, 2009
    I have done it maaany times, by connecting the telephone to 110VAC 60Hz with a 10K resistor in series to test ringers.. The telephone must be on hook or you will fry it.
  6. Electric Al
    Electric Al
    85
    7
    Jan 16, 2014
  7. Martaine2005
    Martaine2005
    3,514
    953
    May 12, 2015
    The pdf bottom right of the chip (under green button) is in English
    Martin
  8. davenn
    davenn Moderator
    13,837
    1,952
    you need to clarify that ... you cannot put DC into a transformer and expect an output voltage
    transformers require AC
    I'm referring to transformers because you specifically refer to primary and secondary
  9. Electric Al
    Electric Al
    85
    7
    Jan 16, 2014
    I did not say that it is a transformer !
    It is a manufactured printed circuit device .
    I will locate it and post a picture !
    PowerDsine
    Ringer.
    P/N:pCR-SINO3V12F20-C
    Vin:12VDC
    Vout:70V rms
    Pout:3W rms
    Frequency:20 HZ
    MADE IN ISRAEL.
    Unit is 2" by 2" and 1/2 " deep .
  10. davenn
    davenn Moderator
    13,837
    1,952
    as I said ..... I only suggested that because you used the words primary and secondary ....
    these are used to describe a transformer
    this is why its important to be very clear describing something
    so that you don't make it even more confusing for those trying to help you :)
    and speaking of being clear ... did you not look at that pic before posting it ???
    its totally blurry and unreadable ... I have deleted it
    there's no point posting something that isn't readable ;)
    try again
  11. Electric Al
    Electric Al
    85
    7
    Jan 16, 2014
    I realized the picture was blurry , and that is why I wrote all the info on the device .
    I probably should not have submitted the image , but that was the best I could do !
  12. davenn
    davenn Moderator
    13,837
    1,952
    OK
    Im not wanting to be or sound harsh, just trying to help you OK :)
  13. Electric Al
    Electric Al
    85
    7
    Jan 16, 2014
    NO PROBLEM ! :cool:
